Old 04-09-2014, 09:13 PM   #1
ghack
ghack is on a distinguished road
2002 SL1
Default leaking transmission cooler line
I have an 02 SL1 with 266k miles. The hex nut that holds the transmission cooler fitting to the inside of the radiator is rusted and coolant is leaking. I have read a number of posts regarding leaky trans cooler lines, but most seem to say the radiator needs to be replaced. If the experts agree that is the best course, I will do that. It just seems that the nut was definitely rusted out(stamped metal) and not holding much. I should be able to replace that nut, possibly add a new rubber gasket under the nut and tight to the fitting, possibly teflon tape, and it would tighten up. I'm guessing there is also a sealing gasket already on the fitting that seals agains the inside face of the hole in the radiator. I don't see the radiator is cracked anywhere. Has anyone had any experience just replacing that nut? Any recommendations? I should mention, the leak is on the lower line. The nut probably cost a couple bucks, the radiator to buy locally is $100. I don't want to replace the nut, and find it leaking again after a few days either.
Add to ghack's Reputation
Rate the quality of this post and help ghack reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ghack is offline   Reply With Quote
Old 04-09-2014, 10:01 PM   #2
bluesl2
bluesl2's Avatar
Default Re: leaking transmission cooler line
Replace the radiator, also I would replace both cooler lines and the fittings that screw into the transaxle where the cooler lines hook into.
Add to bluesl2's Reputation
Old 04-11-2014, 07:08 AM   #3
chriscompton
chriscompton has a spectacular aura aboutchriscompton has a spectacular aura aboutchriscompton has a spectacular aura about
Heads up, if you end up buying new Tranny Coolant Lines, don't buy from Napa! I just made that mistake and the end that goes into the tranny did not fit.
Add to chriscompton's Reputation
Rate the quality of this post and help chriscompton reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chriscompton is offline   Reply With Quote
Old 04-11-2014, 07:47 AM   #4
Madness10
Madness10 will become famous soon enough
Madness10's Avatar
I remember reading that there was someone here in the past that tried to replace the nut and did not hold. These radiators normally crack right there anyways. Do yourself a favor and buy a new radiator and only buy Sella or Delphi, as these are the only ones that will last long. The others may last a couple of years.
Add to Madness10's Reputation
Rate the quality of this post and help Madness10 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Madness10 is offline   Reply With Quote
Old 04-11-2014, 07:37 PM   #5
mrriden
mrriden is on a distinguished road
mrriden's Avatar
2002 SL1
You probably will never get the lower transmission line off the radiator to replace the nut without causing a crack sooo....
Under $50. It's a Silla. Free shipping to your door. Buy it. Replace it, done! I did it in short order on a Saturday. Don't screw with it. Just swap it out. Be happy!
http://www.amazon.com/Shepherd-Auto-...n+sl1+radiator
The how to video:
https://www.youtube.com/watch?v=4nUyGjeLpVs
See if you can bust the transmission lines loose from the radiator before you start. Won't budge? [I suspect they won't on a New England car]buy new lines also. On the trans-axle side they connect with a quick release fitting.
'02 SC2 'The Schnoot'
'94 SL2 'Beauty' (R.I.P.)
'02 SL1 'Silver Lining'
Add to mrriden's Reputation
Rate the quality of this post and help mrriden reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrriden is offline   Reply With Quote
Transmission cooler line replacement? dildog S-Series Tech 29 03-12-2018 11:11 AM
Transmission fluid cooler line broke! Help!! mjspurs23 S-Series Tech 9 07-18-2012 03:11 PM
Is this Dorman Transmission Cooler line the bottom one? Capriman86 S-Series Tech 2 02-28-2012 03:55 PM
Transmission Oil Cooler Line Seal Repair Eazy340 Vue Tech 1 09-10-2008 03:51 PM
Leaking oil cooler CHEMIST L-Series Tech 3 09-06-2008 12:52 PM
