Old 04-08-2014, 08:14 PM   #1
Quteness
Quteness is on a distinguished road
Default Service Traction and Service ESC and P0113
Hi, I have a 2008 Aura XE 3.5L. For a while I was having issues with the car a rough idle. I changed the spark plugs and that fixed it a bit then I took it to the dealer and the distro cap replaced and that fixed it for a while.
Now a few months later the car is idling rough again and everytime I'm in motion the info display in the car cycles between "SERVICE TRACTION" and "SERVICE ESC". Every now and then a "ESC OFF" is thrown in there. Using my laptop I'm getting a P0113 code which says something about the "Intake Air Temperature Circuit High Input"
I'm not really sure where to go from here and any help would be appreciated. Thanks!
Add to Quteness's Reputation
Rate the quality of this post and help Quteness reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Quteness is offline   Reply With Quote
Old 04-09-2014, 01:04 AM   #2
Default Re: Service Traction and Service ESC and P0113
DTC P0113: Intake Air Temperature (IAT) Sensor Circuit High Voltage
The intake air temperature sensor is internal to the maf sensor (between air filter and throttle body). Maf cleaner can be used for maintenance and exercising the connector once or twice (disconnect/reconnect) may improve things. Some error codes are reset on the next engine start while others may require several engine cycles before the check engine light resets.
The ABS/TC and ESC are all part of the braking system enhancements. Either an intermittent issue is disabling the ABS/TC/ESC system or (some models) the battery/alternator system isn't regulating correct power - whether the battery or alternator is at fault requires fault isolation/testing. Battery life is limited so a review of battery warranty can tell you whether or not the battery is due for replacement. Battery and alternator testing are usually free from auto stores selling batteries.
Old 04-09-2014, 01:47 PM   #3
greenman
2009 AURA XE
firstly: "distro cap"?
113 code means either the IAT sensor itself is bad or there's a circuit issue. the IAT sensor is combined with the MAF sensor. u can try replacing the sensor but there's no guarantees without proper testing.
Add to greenman's Reputation
Old 04-10-2014, 11:31 PM   #4
Aura3.5XE
Aura3.5XE is on a distinguished road
I had the same thing happen to my Aura XE 3.5, most likely it is related to your Mass Air Flow sensor. Before you replace it, remove tubing and electrical tape from the connector of the MAF to see there is no pinched or bad wires. In my situation the harness seemed like it had been replaced, so about 8-10 inches from the connector back it had a butt connectors and two wires had come off from them, triggering "Service Traction" and "Traction Off" and having the car stall and miss. Spliced them back in and problem solved.
Add to Aura3.5XE's Reputation
Rate the quality of this post and help Aura3.5XE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Aura3.5XE is offline   Reply With Quote
Service ESC Service Traction rob.ski Aura General 5 03-30-2012 06:47 PM
Service Traction/Service ESC warnings Dev_56 Aura General 6 02-22-2012 02:37 PM
Service traction?!?! help Mikey07! Aura General 8 12-13-2011 10:05 AM
Service Traction and SES lighting up cverstij Aura General 23 11-05-2008 11:05 AM
Service Traction ?? humfrz Aura General 3 10-19-2008 01:01 PM
