Old 08-17-2015, 12:12 PM   #61
VentureForth
VentureForth has a spectacular aura aboutVentureForth has a spectacular aura aboutVentureForth has a spectacular aura about
VentureForth's Avatar
2006 ION-3 Sedan
Default Re: Have You Experienced the Ignition Switch Issue?
Here was the final disposition.
Was offered for $115 to troubleshoot then apply if things other than recall were affected. If only the recall fix was needed, the diagnostic fee was refunded. I told them to just fix the recalled items and if the problem persisted, I would fix the rest myself. He agreed.
Two recalls were addressed: 9100400 for ignition switch replacement and 9100495 for replacing ignition lock cylinder and key.
No work to the housing was necessary. 2.5 hours and $0.00.
First time I have ever been satisfied by the dealership service center.
For anyone else who can't shut their engine off, see photo for the green plug you want to disconnect.
Thanks to all!
Add to VentureForth's Reputation
Rate the quality of this post and help VentureForth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VentureForth is offline   Reply With Quote
Old 11-24-2018, 07:12 PM   #62
Psycho-Ions2
Psycho-Ions2 is on a distinguished road
2007 ION-2 Sedan
2004 ION-3 Quad Coupe
I am 3rd owner of an 07 Ion, within 1 month of ownership (July 2017) I ran into the Passlock issue, car wouldn't start half the time, then when it would start and I put it in drive a padlock light came on, and the car only drove with half power.
So I did a junkyard part swap the first time, I was lucky enough to find one with a key in it. The second time I had time I had an issue, the key would randomly get stuck in the cylinder and wouldn't release so the power/accessories would stay on and drain the battery, only way I could leave the car without draining the battery was to remove the ignition fuse everytime I got out.
Took it to a Chevy dealer and got it replaced, last winter (November 2017) I had the power steering light come on, and didn't have very good control of the steering a few times, so I took it to the same dealer to have that recall fixed. In May (2018) the recalled ignition part that was supposedly fixed started acting, once a week or every other week when I'm driving the key will pop backwards into the Acc. position and the car shutsoff.
Also if the steering column gets bumped while in drive, the key pops out and the car also shuts off (Worse than previously mentioned issues). Right now it sits in my driveway with a rod that blew a hole through the crankcase.
My mother owns an 03 Ion that I work on for her most of the time. She's had 3 ignitions cylinders replaced, the first time I did a junkyard swap, second time ot was replaced by a dealership, the 3rd time I bought the part from PartsGeek.com, and had a mechanic friend replace it, because both times the dealerships replaced it, it locked her key in the ignition just like mine.
I think after all of this crap I'm going to say adios to GM products, GM has been apart of my family as far back as I can remember, my grandpa used to work at the Leed's Chevy plant in the 60-80's up til they closed the doors. I've had family members with Dodge's, Ford's, Subaru's, Mitsubishi's, and Toyota's from 70's to the 2010's, out of all of them the ones that had the most issues were with GM, Toyota, and Ford.
Add to Psycho-Ions2's Reputation
Rate the quality of this post and help Psycho-Ions2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Psycho-Ions2 is offline   Reply With Quote
2004 vue ignition switch issue haloelite482 Vue Tech 3 02-14-2014 04:33 PM
Ignition Switch Issue.... AJEsquire Vue Red Line 14 04-23-2013 10:43 PM
2007 Ion startig issue (not ignition switch!) James614 Ion Tech 9 04-03-2013 10:21 AM
Saturn Ion 2 (2007) Ignition Lock or ignition Switch Manual Transmission infinitezero Ion Tech 5 11-25-2011 05:47 PM
'94-SL1 - ignition key in switch chime - ignition switch bezel question wrchism S-Series Tech 1 01-24-2005 02:09 AM
