Old 03-26-2014, 09:27 AM   #1
1916fenian
1916fenian is on a distinguished road
1992 SL1
Default coolant fan modification
I just bought a 92 SL1 and the previous owner put the coolant / radiator fan on a push switch on the dash, can anyone here think of why this was done?
Obviously the fan motor functions so perhaps something before the motor is faulty?
Add to 1916fenian's Reputation
Rate the quality of this post and help 1916fenian reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1916fenian is offline   Reply With Quote
Old 03-26-2014, 09:33 AM   #2
1916fenian
1992 SL1
Default Re: coolant fan modification
also, does anyone have a source for a clear schematic / diagram for the wiring so I can try to rewire it back to original?
Old 03-26-2014, 09:35 AM   #3
cleverbot
cleverbot is on a distinguished road
cleverbot's Avatar
1994 SC2
My 94 had the same thing done to it. It was because of the ECTS never being replaced. Or the thermostat being replaced because soon after replacing the ECTS my thermostat failed. So replacing them both and rewiring everything back to the way it was should fix those issues.
1994 Saturn SC2 (5-speed) with 240k. (RIP Junked 11/16/12)
1993 Toyota Tercel STD (4-speed) (sold)
1998 Saturn SL2 125,000 miles (RUNNING FANTASTIC!!!)
2012 Chevy Sonic 26,000 miles (5-speed)
Add to cleverbot's Reputation
Rate the quality of this post and help cleverbot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cleverbot is offline   Reply With Quote
Old 03-26-2014, 09:58 AM   #4
Diagram in post 2
http://www.saturnfans.com/forums/sho...d.php?t=194113
In addition to a faulty ECTS (which will never turn the fan on, regardless of temp), some people put in a manual fan switch because of the way the temp gauge was calibrated. From '91 to '95, normal warm operating temps were between 1/2 on the gauge, and about 3/4 on the gauge. Fan turned on around the 3/4 mark, which, on the gauge face, seemed close to the red/ overheat area. That freaked people out, even though that was within spec, so they installed manual fan switches to turn the fan on over the 1/2 mark.
For '96-02, the gauge was recalibrated. 1/2 on the old gauges was now 3/8 on the new gauges. 3/4 on the old gauges now showed as 1/2 on the newer gauges, even though the actual coolant temp was the same in both cases. Less panicky owners
Old 03-26-2014, 10:29 AM   #5
colonelhogan44
colonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nice
colonelhogan44's Avatar
I installed one in my car because I wanted to be able to turn the fan on in traffic to keep the temperature constant.
Mechanical Engineer - I make cool parts.
2005 Volvo S40 T5 AWD - 71k
1998 SL2 - 244k (Gone, never forgotten)
1993 Geo Tracker 4x4 - 134k
1996 Geo Tracker 4x4 - 107k
1987 Mercedes 300D - 156k
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-26-2014, 09:36 PM   #6
Signmaster
Signmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to behold
Originally Posted by alordofchaos View Post
Diagram in post 2
Keep in mind also that the only place the gauges are close is near the 1/2 way point. Based on what I've seen with the '95 and earlier cars, some of the panic is probably due to not understanding that the gauge sweep is completely different. 1/4 on the pre '96 cars is around 180 degrees, and 1/2 is 208-210 IIRC. The same range sweep on the later cars is around 60-65 degrees temp change, as compared to 25-30 degrees temp change on the earlier cars.
The same applies on the earlier cars from the 1/2 point to the 3/4 point. That movement is only 20-25 degrees actual temp change.
Those combined with the ECTS variations, gauge variations, and higher fan on temp of the earlier cars have some early cars pegging the red before the fan kicks on.
Air filter modification 99 sl1 dddaaa S-Series Tech 32 04-11-2009 08:53 PM
wow, 3 MPG better with my modification sdowney717 S-Series General 23 05-17-2006 12:16 PM
modification Azn_IoN Ion General 8 06-30-2005 11:11 AM
DIY modification for flashers (LED mod) Scotto Vue General 3 07-03-2004 11:15 PM
The *NEW* Vue modification Page SQVue Vue General 6 07-24-2003 12:56 AM
