#1 |
![]() Join Date: Feb 2014
2007 ION-3 Sedan
Seem like every week iI have a new code new issue. My SC2 is now throwing U1301 and am at a loss on where to start to trouble shoot. Any advice?
#2 |
U1301 indicates a loss of communication among the electronic modules. A wiring check connecting every module is the minimum needed to determine where a short or break occurred to cause this error code.
VCX NANO |
#3 |
2007 ION-3 Sedan
Thanks for the info. Looks like fun
#4 |
2007 ION-3 Sedan
Is it at all possible that it could just be the battery terminals/ connection?
#5 |
If it were the main battery terminals and connections, there would be other symptoms like dimming gauge lights or losing radio presets at random. If you live in humid areas of the country, older wiring may inherit corrosion issues from damp conditions. If engine work was ever done, wiring harnesses may chafe on sharp metal corners. Plastic insulation will dry rot from uv exposure resulting in cracked insulation.
VCX NANO |
#6 |
![]() ![]() ![]() ![]() Join Date: May 2011
Got anything plugged into the power socket?
I have seen U codes caused by phone chargers...
2002 Silver SL2, manual, 5th gear swap (.605), 80,000 miles, black badges, 205/60R15 "H" rated tires, 5mm spacers rear... Pennzoil Maximum Power 0W-30, Champion COS3600... NGK BKR6E-11 spark plugs |
#7 |
2007 ION-3 Sedan
Yes I do, a radar detector and XM radio.
#8 |
Bazinga!
Reset the code, and try unplugging one or both before starting...
Bookmarks |
U1301/gauge problems | Petess | S-Series General | 4 | 09-11-2013 11:09 PM |
F/S Actron cp9580 code connect scanner/ code reader | ShawnV | S-Series General | 0 | 06-13-2013 05:25 PM |
SL2 Error Codes P1626 U1064 U1096 U1301 P0341 | HotCookCpl | S-Series Tech | 12 | 08-12-2011 09:39 AM |
Need my paint code, 96 sc2 black/gold metallic (I'm missing the trunk panel w/code) | DJboozeAlot | S-Series General | 3 | 03-18-2011 10:26 PM |
U1301 - ECTS Related? | nivlem7 | S-Series Tech | 11 | 02-18-2008 05:54 AM |
