Old 03-05-2014, 10:45 PM   #1
grasshopper
grasshopper is on a distinguished road
Default cobalt steering column
So this just in. Cobalt power steering motor will work in our cars. Yah i know you knew that. But what i didnt know was the whole unit will not. It fits but it doesnt speak to our bcm. This is unproven but so far my findings. Any othere have tried this?
Add to grasshopper's Reputation
Rate the quality of this post and help grasshopper reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
grasshopper is offline   Reply With Quote
Old 03-05-2014, 11:02 PM   #2
satlite440
2001 SL2
Default Re: cobalt steering column
no the epscm(electric power steering control module )will not probably work due to the fact it has a different vin and rpo list programmed into it.. also without some research i have no time for the gm high speed lan and low speed lan&class 2 comm pins on the connecter may have a different pin out than your car.. possably the same but not sure but it deffanatly has the wrong programming for your car..just change the moter over
Old 03-05-2014, 11:03 PM   #3
2006 ion2
2007 ION-2 Sedan
chevy and saturn use different programs altogether, even different protocols. not to mention for sure different ECUs and possibly even different BCMs, so it makes perfectly good sense. anything computer controlled won't work unless it's a transmission, and you use the saturn TCM and sensors.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Steering wheel and steering column problems. HELP!! nhsbaseball24 S-Series Tech 4 04-13-2013 08:42 PM
steering intermediate shaft to steering column bolt flymanansh Aura General 4 02-07-2012 03:40 PM
steering column VueGuy168 S-Series Tech 0 06-10-2009 09:53 PM
rubbing noise steering wheel/steering column on 04 Vue ynotps Vue General 6 03-03-2005 07:59 PM
