Old 02-25-2014, 01:34 PM   #1
kosoku
kosoku is on a distinguished road
Default 2.2l Ecotec Compatability List
Hi all,
I've had my Vue for about 6 months and put about 5,000 miles on her. 2002 2.2L, 5 spd.
The odometer is off, but the engine is approaching 200,000 miles. From what I've read, that seems to be near the record for long life in early 2.2s prior to '04.
I originally bought the Vue for a temporary commuter vehicle, but the versatility of it has really grown on me. 30 mpg on the highway and enough utility to carry nearly anything.
Anyhow, while the engine still runs like a new one, I'm looking to keep the car after the engine dies and want to shop around for a replacement engine in advance. I've found some threads of horror stories about cam sensors and crankshaft position sensors being different so I was wondering if we could compile a list of which year/vehicle 2.2 engines work with which modifications?
Add to kosoku's Reputation
Rate the quality of this post and help kosoku reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kosoku is offline   Reply With Quote
Old 02-25-2014, 01:53 PM   #2
PortugalFocus
PortugalFocus's Avatar
Default Re: 2.2l Ecotec Compatability List
Ask and you shall receive....
A thru E interchange as shown in notes.
Chevrolet 2.2L (4-134).
VIN "D" opt. L61 (Vue & HHR).
VIN "F", opt L61 (others).
AIR check valve for Calif is mounted on the exhaust manifold.
A
B fits by plugging AIR system.
C fits as a service replacement part.
D & E fit by switching heads.
E fits by switching heads.
Exhaust manifold is not drilled & tapped for AIR check valve (Federal).
Oil pan differs between Saturn & GM models.
W/o EGR port in head.
B
C fits by switching AIR system.
D fits by switching AIR system & head.
Exhaust manifold has AIR check valve system (Calif).
C
D fits by switching head.
Plugged exhaust manifold is drilled & tapped for AIR check valve (service
replacement part).
D
C fits by swiching head.
replacement part).
EGR port in head.
fits by switching intake cam.
E
A & C fit by switching head.
D fits as a service replacememt part.
EGR port in head.
A:Cobalt '05 2.2L (VIN F, 8th digit), exhaust manifold is not drilled & tapped f
A: or AIR check valve
A:Cobalt '06 2.2L (VIN F, 8th digit, opt L61), w/o AIR check valve; exhaust mani
A: fold is not drilled & tapped for AIR check valve
A:HHR '06 2.2L (VIN D, 8th digit), exhaust manifold is not drilled & tapped for
A: AIR check valve
A:Ion '03 (2.2L VIN F, 8th digit), exhaust manifold is not drilled & tapped for
A: AIR check valve, w/o EGR port in head
A:Ion '04-05 2.2L (VIN F, 8th digit opt L61), exhaust manifold is not drilled &
A: tapped for AIR check valve, w/o EGR port in head
A:Ion '06 2.2L (VIN F, 8th digit, opt L61), w/o AIR check valve; exhaust manifol
A: d is not drilled & tapped for AIR check valve
A:Malibu '04-05 VIN Z 4th digit (New Style), 2.2L (VIN F, 8th digit), exh man is
A: not drilled & tapped for valve, w/o EGR port in head
A:Malibu '06 2.2L (VIN F, 8th digit), exh man is not drilled & tapped for AIR va
A: lve
A:Pursuit '05 (2.2L, VIN F, 8th digit), exhaust manifold is not drilled & tapped
A: for AIR check valve
A:Pursuit '06 2.2L (VIN F, 8th digit), w/o AIR check valve; exhaust manifold is
A: not drilled & tapped for AIR check valve
A:Vue '02-05 2.2L (VIN D, 8th digit, opt L61), exhaust manifold is not drilled &A: tapped for AIR check valve, w/o EGR port in head
A:Vue '06 2.2L (VIN D, 8th digit, opt L61), exhaust manifold is not drilled & ta
A: pped for AIR check valve
B:Cobalt '06 2.2L (VIN F, 8th digit, opt L61), w/AIR check valve (Calif)
B:Ion '06 2.2L (VIN F, 8th digit, opt L61), w/AIR check valve (Calif)
B:Pursuit '06 2.2L (VIN F, 8th digit), w/AIR check valve (Calif)
C:Cobalt '05 2.2L (VIN F, 8th digit), exhaust manifold is drilled & tapped for A
C: IR check valve
C:Cobalt '06 2.2L (VIN F, 8th digit, opt L61), w/o AIR check valve; exhaust mani
C: fold is drilled & tapped for AIR check valve
C:HHR '06 2.2L (VIN D, 8th digit), exhaust manifold is drilled & tapped for AIR
C: check valve
C:Ion '03 (2.2L VIN F, 8th digit), exhaust manifold is drilled & tapped for AIR
C: check valve, w/o EGR port in head
C:Ion '04-05 2.2L (VIN F, 8th digit opt L61), exhaust manifold is drilled & tapp
C: ed for AIR check valve, w/o EGR port in head
C:Ion '06 2.2L (VIN F, 8th digit, opt L61), w/o AIR check valve; exhaust manifol
C: d is drilled & tapped for AIR check valve
C:Malibu '04-05 VIN Z 4th digit (New Style), 2.2L (VIN F, 8th digit), exh man is
C: drilled & tapped for AIR valve, w/o EGR port in head
C:Malibu '06 2.2L (VIN F, 8th digit), exh man is drilled & tapped for AIR valveC:Pursuit '05 (2.2L, VIN F, 8th digit), exhaust manifold is drilled & tapped for
C: AIR check valve
C:Pursuit '06 2.2L (VIN F, 8th digit), w/o AIR check valve; exhaust manifold is
C: drilled & tapped for AIR check valve
C:Vue '02-05 2.2L (VIN D, 8th digit, opt L61), exhaust manifold is drilled & tap
C: ped for AIR check valve, w/o EGR port in head
C:Vue '06 2.2L (VIN D, 8th digit, opt L61), exhaust manifold is drilled & tapped
C: for AIR check valve
D:Ion '03 (2.2L VIN F, 8th digit), exhaust manifold is drilled & tapped for AIR
D: check valve, w/EGR port in head
D:Ion '04-05 2.2L (VIN F, 8th digit opt L61), exhaust manifold is drilled & tapp
D: ed for AIR check valve, w/EGR port in head
D:Malibu '04-05 VIN Z 4th digit (New Style), 2.2L (VIN F, 8th digit), exh man is
D: drilled & tapped for AIR valve, w/EGR port in head
D:Vue '02-05 2.2L (VIN D, 8th digit, opt L61), exhaust manifold is drilled & tap
D: ped for AIR check valve, w/EGR port in head
E:Ion '03 (2.2L VIN F, 8th digit), exhaust manifold is not drilled & tapped for
E: AIR check valve, w/EGR port in head
E:Ion '04-05 2.2L (VIN F, 8th digit opt L61), exhaust manifold is not drilled &
E: tapped for AIR check valve, w/EGR port in head
E:Malibu '04-05 VIN Z 4th digit (New Style), 2.2L (VIN F, 8th digit), exh man is
E: not drilled & tapped for valve, w/EGR port in head
E:Vue '02-05 2.2L (VIN D, 8th digit, opt L61), exhaust manifold is not drilled &
Add to PortugalFocus's Reputation
Rate the quality of this post and help PortugalFocus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-25-2014, 10:11 PM   #3
jrw1621
jrw1621 will become famous soon enough
2003 VUE 2.2L
The reason for the early failure of the first few years of 2.2L engines has to do with bad timing chain oiler, guides and tensioner. Preventive maintenance of updating these items to the new design will help your engine last indefinitely.
I would not put my time and resources into preparing to replacing the entire engine but rather this preventative maint.
PS: in my first 6 months of ownership, I have added 25k miles returning 26.1 mpg combined.
http://www.fuelly.com/driver/jrw1621/vue
Add to jrw1621's Reputation
Rate the quality of this post and help jrw1621 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jrw1621 is offline   Reply With Quote
Old 04-10-2014, 08:26 PM   #4
mprice789
mprice789 is on a distinguished road
Will a 2007 Malibu 2.2 Vin F engine work in a 2005 2.2 vin D VUE.
Add to mprice789's Reputation
Rate the quality of this post and help mprice789 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mprice789 is offline   Reply With Quote
gm compatability? dynonacht S-Series Tech 4 06-28-2012 04:16 PM
Compatability of used BCM Kinley L-Series Tech 2 08-19-2010 01:24 PM
Air bag compatability Raptor Cardel S-Series Tech 1 02-24-2010 08:56 PM
91 - 9x Compatability? sl2collector S-Series Tech 1 01-25-2007 08:43 PM
96 & 99 compatability Baizal S-Series General 2 02-01-2005 10:23 PM
