Old 02-18-2014, 08:16 PM   #1
ZakPatin93
ZakPatin93 is on a distinguished road
1997 SC1
Dizzy Automatic Transmission Ran Without Fluid
I had installed some new transmission cooler lines in my 1997 SC1 and never replaced the tranny fluid that leaked out. I pulled the car out of the shop and to its parking spot about 50 yards away. The car was driving fine until i got just about to the parking spot and it started smelling like something was burning and the car stopped moving.
I know that an automatic transmission needs fluid to run so that explains why it stopped moving. My question is did I mess up my tranny? Whats your opinion on how bad the damage is.
If your just going to bash me for doing this then walk along. I know it was a stupid idea and quite frankly I don't give a crap. Just wanted some friendly advice
Zak Patin
1997 SC1
Add to ZakPatin93's Reputation
Rate the quality of this post and help ZakPatin93 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ZakPatin93 is offline   Reply With Quote
Old 02-18-2014, 09:08 PM   #2
anmasher
anmasher's Avatar
Default Re: Automatic Transmission Ran Without Fluid
You shouldn't have lost more than a cup or so from those lines. If that is the case the transmission will be just fine and there is some other reason for the car to stop moving...
Approximately how much came out?
Add to anmasher's Reputation
Rate the quality of this post and help anmasher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-18-2014, 09:13 PM   #3
climbski
climbski has a spectacular aura aboutclimbski has a spectacular aura about
1999 SW2
Seems unlikely you messed up the tranny that fast by being low.
I'd guess you spilled some on the exhaust and that would explain the smell.
One way to find out. Add some fluid and see what happens.
Add to climbski's Reputation
Rate the quality of this post and help climbski reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
climbski is offline   Reply With Quote
Old 02-18-2014, 09:14 PM   #4
ZakPatin93
1997 SC1
I'm not sure. It had to have been a good amount. I started the project 4 months ago with a radiator. The tranny cooler lines were seized in the old radiator so i just bought new ones and finally just put them on this weekend. The car had been sitting outside so I wouldnt be able to tell if it leaked out during the past 4 months.
Zak Patin
1997 SC1
Old 02-18-2014, 09:17 PM   #5
Signmaster
The only way to find out for sure is to get it filled and see what happens. I'm sure it's not the first time a tranny has been run low on fluid. I've seen quite a few autos run very low on fluid and survive just fine.
Old 02-18-2014, 09:19 PM   #6
ZakPatin93
1997 SC1
Lets hope so!
Thanks
Zak Patin
1997 SC1
Old 02-18-2014, 10:33 PM   #7
Modding_out
Modding_out is on a distinguished road
Modding_out's Avatar
I would suspect you dumped quite a bit of fluid from those lines, but in 50yards your not going to mess up a thing..... re fill with oil and see what happens
Not to scare you but running w/o fluid in the tranny can cause it to seize in 1st gear.. i brought a sl2 like that, but the dumb ass drove it 10 miles home. Your fine
Add to Modding_out's Reputation
Rate the quality of this post and help Modding_out reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Modding_out is offline   Reply With Quote
Old 02-19-2014, 05:42 AM   #8
SL19302
SL19302's Avatar
2002 SL1
If the Transmission was low to begin with before replacing the cooler lines that would explain how the Transmission stopped functioning, Fill the fluid with DEX III to the full COLD line and try to drive it and see what happens, After about 10-15 miles re-check the fluid and make sure its on the FULL line, The car has to be HOT and LEVEL.
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 02-19-2014, 10:05 AM   #9
dbetz
dbetz will become famous soon enoughdbetz will become famous soon enough
1999 SW2
2000 SL
I would say fill er up and see what happens. A couple of years ago (before I found this site), I got sideswiped by a speed racer power sliding through the curves on our dirt road. Hit the left front fender, but broke the strut and knocked the CV joint (?) out of the trans. Poured trans fluid all over. Had it towed to a (recommended) place to have it fixed, who ended up being morons (they couldn't even install a driver side mirror correctly). They put it back together but never bothered to check the trans fluid. Drove it for a while (many miles) with a weird whining noise I couldn't figure out. On a complete whim, I checked the trans fluid to find it off the dipstick. Put 3 quarts in I think. That was probably 40k miles ago.
It is possible that it did damage, but I think you would have to do a lot more than you did to break it. Likely there is something else.
Thanks! David
1999 SW2 Auto 150k miles; Dark Plum Metallic
2000 SL 5-Speed 214k miles; Silver
Add to dbetz's Reputation
Rate the quality of this post and help dbetz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dbetz is offline   Reply With Quote
Old 02-19-2014, 01:02 PM   #10
Correct me if I'm wrong but about half the xmission oil is in the torque converter. Since the t/c also pumps oil thru the system, losing fluid would imply less in the t/c. T/c's can't work if fluid isn't there to xfer power from the engine to the xmission, the heart and sole of all torque converters. If the t/c is low on fluid then the engine can't power the xmission via the fluid coupling. I would presume no damage as no fluid coupling occurred. Top off with fluid and let the engine idle while manually shifting thru all gears, pausing for about 15 seconds in each gear to let fluid run thru the valve body passages (and purge itself of any air). Once this is done and tranny topped off, the t/c being full will automatically be restored to being the fluid coupling it was designed to be and hopefully a perfectly operating xmission. Just drive tentatively around the block and observe each shift to allow the xmission to work.
Old 02-19-2014, 07:05 PM   #11
ZakPatin93
1997 SC1
Thank you for all the help. Ill give it a try this weekend. I'm hoping the burning I was smelling was harmless.
Zak Patin
1997 SC1
Automatic Transmission Fluid unit731 Ion General 18 06-15-2013 10:56 PM
Automatic Transmission Fluid x2006nzl Vue Tech 8 02-11-2012 11:24 AM
Transmission Fluid for 1992 SL1 Automatic. Catholic S-Series Tech 17 04-12-2011 06:31 PM
Saturn Automatic Transmission Fluid Tankrider7 S-Series General 12 12-26-2009 04:06 PM
How to change the automatic transmission fluid? atikovi Ion Tech 5 07-23-2006 10:49 PM
