Go Back   SaturnFans.com Forums > Models > Saturn Relay > Relay General
Old 02-06-2014, 10:42 AM   #1
Paulomancha
Paulomancha is on a distinguished road
2005 RELAY-2
Post transmission trouble
hi everyone
My name is Paulo and I just bought a 2005 saturn relay
when I did a test drive everything worked fine but when I took it home I start noticing some transmission troubles
if I press the gas to hard when start driving, the transmission shakes and then make a hard quick when engage then make another quick when engage on the next gear after that works fine
if I don't press the gas to hard when start driving it starts ok but still makes a quick on next gear.
can someone advise me what can be the consequences if I continue driving like that.
Add to Paulomancha's Reputation
Rate the quality of this post and help Paulomancha reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Paulomancha is offline   Reply With Quote
Old 08-09-2014, 06:25 PM   #2
pierrot
pierrot's Avatar
Default Re: transmission trouble
It would be easier for others to help if your description of the problem was developed more clearly. The highlighted and colored words are not clear as to their meaning and usage here, along with the odd sentence structure.
294,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 04-27-2015, 09:01 PM   #3
torriciano
torriciano is on a distinguished road
80 K mi. Relay and unhappy from day 1. Piece of ****.
Add to torriciano's Reputation
Rate the quality of this post and help torriciano reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
torriciano is offline   Reply With Quote
Old 01-01-2016, 03:12 PM   #4
jiggie
jiggie is on a distinguished road
Mine did that a few times when it started getting really cold outside. When I had it in for its oil change the mechanic said at 90k it calls for a trans fluid service. Might try that first. Dealership quoted me 180 for a transmission flush and filter exchange.
Add to jiggie's Reputation
Rate the quality of this post and help jiggie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jiggie is offline   Reply With Quote
Transmission Trouble YKDavid S-Series General 0 10-05-2013 01:14 PM
transmission trouble please help good ol diy'er S-Series General 4 05-06-2012 08:45 PM
Trouble with Transmission Trouble Codes Toaster_Man S-Series Tech 0 05-22-2008 06:32 PM
Transmission trouble or ECM HELP!!!! nitronick L-Series Tech 1 03-01-2007 05:59 PM
transmission trouble firsttimesaturn S-Series Tech 5 04-04-2006 08:48 AM
