Old 01-30-2014, 03:25 PM   #1
Minnesotakid1
Minnesotakid1 is on a distinguished road
Default 2001 Saturn SL1 Transmission problems
Hi, I have a 2001 Saturn sl1 with the L4 1.9L engine, has only 96000 miles on it and has been a good car. The other day when it was real cold I went out and started it, and let it warm up for about 10-15 min, when I tried to shift it in to Reverse there was nothing, I had forward gears but no reverse. I let it roll down the driveway and I could use forward gears but could no faster than about 30. There were no lights or warning messages on the dash. So I put it in garage and tried it again about 6 hours later and it was fine I had reverse, and could run as normal. So I ran it a few days and it seemed better. Then one morning I come out and again no reverse, so I took it to local shop. They said it had codes P0731, P0732, and P0733 and 1599. The latter they weren't too concerned about. They cleared the codes and the car ran fine for them without issue, they put about 100 miles on it and no problems. They tested the electrical and it was fine, they tested the pressure and it was fine, no leaks, etc everything to spec. They tested the battery and it was at 14.4 so they said that not thee issue. So they let it sit over night and again no reverse and they get the same codes. They think it is the Valve body needs to be replaced. Is that the fix, or could it be the PCM is losing the codes over night and then the engine is confused when we start it up and throws the codes? Anything else it could be with these symptoms? IT has a automatic transmission and fluid looks good. Just want to make sure this is the correct fix to go with. Thanks
Add to Minnesotakid1's Reputation
Rate the quality of this post and help Minnesotakid1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Minnesotakid1 is offline   Reply With Quote
Old 01-30-2014, 08:07 PM   #2
2.2ecotec
2.2ecotec is on a distinguished road
2.2ecotec's Avatar
Default Re: 2001 Saturn SL1 Transmission problems
although this is not an L series you have. we will try to help you. How cold is it where you live and is the car garage kept or outside
Add to 2.2ecotec's Reputation
Rate the quality of this post and help 2.2ecotec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2.2ecotec is offline   Reply With Quote
Old 01-31-2014, 09:48 AM   #3
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
You have an S series car, there's like 3 guys here in the L series forum that answer S series questions. Repost your question in the S series tech forum and you'll get much more help.
Jerry N
Groucho Marx
Add to s3nfo's Reputation
2001 SL1 Manual Transmission problems dhunch S-Series Tech 22 08-07-2014 06:52 AM
2001 Saturn Sl2 starting problems Vfranco2 S-Series Tech 3 03-04-2012 10:44 AM
2001 SC1 Transmission Problems Shadowfxd S-Series Tech 2 11-06-2011 08:20 AM
2001 Saturn SWP transmission help. NightWalker86 S-Series General 1 10-28-2011 08:16 PM
2001 Saturn SC1 starting problems The Grey Elf S-Series Tech 5 08-08-2011 09:59 AM
