Old 01-28-2014, 06:36 PM   #1
Patzekd
Patzekd is on a distinguished road
2003 ION-1 Sedan
Default Ion manual shift cable broken
Got an 03 Saturn ion 1 Base, 5 speed manual. Last couple weeks I've noticed in the real cold weather the shifter is rather stuck/frozen until the car warms up , then it shifts great. I've been letting it warm up before I drive it and its worked out well....until today. Got in it after work and and the right shifter cable snapped. Pulled the boot and actually drove it home using vise grips, real pain. But I have it home now and started looking for replacement shift cable and can't find any. Called the Gm dealership they want 140$ for one cable. Has anyone else ran into this problem? is there a generic Gm cable that can be used? Or even the Ion redline cables? All the shift assemblies I found on eBay are for automatic ions ... Any help appreciated let me know
Thanks
Add to Patzekd's Reputation
Rate the quality of this post and help Patzekd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Patzekd is offline   Reply With Quote
Old 01-28-2014, 09:14 PM   #2
ddemier7
ddemier7 will become famous soon enoughddemier7 will become famous soon enough
ddemier7's Avatar
2004 ION-1 Sedan
Default Re: Ion manual shift cable broken
Try the junk yard
Add to ddemier7's Reputation
Rate the quality of this post and help ddemier7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ddemier7 is offline   Reply With Quote
Old 01-29-2014, 12:07 AM   #3
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Just an FYI that the shift cables on 2003 models (p/n 22670918) are different than those on 2004-2007 models (p/n 15277760). I've attached a TSB that explains the differences.
TSB_#03-07-29-007_Shift lever cable changes.pdf
Also, the shift cables in Red Line Ions (p/n 10383794) are different from regular Ions.
2007 Chevy Equinox LT 183K miles
Add to ruley73's Reputation
Old 01-29-2014, 12:21 AM   #4
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Wrench Re: Ion manual shift cable broken
We have a Saturn Junkyard here in town, if you want give them a call at 417-626-2277 Spencers Saturn's we are central standard time located in area code 64801
Old 01-29-2014, 11:19 AM   #5
Patzekd
2003 ION-1 Sedan
Thanks for the tips , would that saturn junk yard ship do u know ? I'm in pa
Old 01-29-2014, 02:44 PM   #6
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Im sure they would. Just add it to the bill... lol
Fixing a broken shift cable eyelet delsydsoftware S-Series Tech 16 10-19-2013 06:24 AM
Manual transaxle shift cable lubrication.... emsvitil Vue Tech 0 03-15-2011 10:55 PM
Shift Cable transmission mount broken... Lodogg2221 S-Series Tech 7 08-03-2010 10:25 AM
Broken shift cable end ericksona S-Series Tech 4 08-06-2009 08:26 AM
Manual shift cable binds: Fix or replace? paulg7 S-Series General 1 01-15-2007 04:00 AM
