Old 09-11-2017, 07:17 PM   #21
Moon
Moon is on a distinguished road
Default Re: 1997 SL MYSTERIES; Power Drain
I pressed the power lock on my passenger door to close all lock and the button sort of caved-in which then caused all the power lock motors on all doors to whir and click constantly. Can I just disconnect the switch on the door switch that started this to get everything back to normal without having to replace/fix anything since I am low on money?
Add to Moon's Reputation
Rate the quality of this post and help Moon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Moon is offline   Reply With Quote
Old 09-11-2017, 07:42 PM   #22
hudypete1
hudypete1 is a jewel in the roughhudypete1 is a jewel in the roughhudypete1 is a jewel in the rough
2007 ION-3 Sedan
You should be able to just disconnect that one switch and all the rest should work properly.
I don't recall enough of the schematic, but it seems to me that the RKE and other door lock button (passenger side?) should still work. I think that these switches are wired in parallel and complete a ground, any one of them completes a ground and that signal is used to power the solenoids to lock the door.
I changed a non-power window/lock SL2 to all powered and had issues with one of the locking solenoids. So I just did not connect that one switch until I had gotten a replacement.
For replacements, if you go to a U-Pull salvage yard they should be under $10 for a switch. Take some testing equipment with you (either will work):
  • multimeter (and do continuity check across the switch while pressing the button)
  • 9V battery, wire, and light bulb (like from a side marker running bulb). Wire up a simple circuit and just plug the switch into it to see if the connections are good.
If you are lost at what I just described above, I can try to pull up schematics and give you pointers.
As I recall, 95-99 all use the same switch and I saw a ton of SLs in every yard I went to over the past 2 weeks (7 yards in 10 days! It was a hoot!). But don't quote me on the compatibility.... check it out yourself using the swap guide which is a sticky somewhere.
Peter in Lansing MI
current cars:
94 SW2 (White, automatic)
99 SL2 (Silver Plum, manual)
99 SL2 (Dark Blue, manual)
04 Ion 3 (Berry Red, 2.0L automatic)
07 Ion 3 (Cypress Green, 2.4L, manual)
Add to hudypete1's Reputation
Rate the quality of this post and help hudypete1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hudypete1 is offline   Reply With Quote
Old 09-11-2017, 09:01 PM   #23
Moon
ok... thanks
Old 09-12-2017, 10:33 AM   #24
trottida
trottida's Avatar
New switches are only $20.77 on Amazon with free shipping (link below). If you're going to grab a used one from an auto wrecker; take the one from the passenger door as it would have been used less. They are both the same but you have to move the switch into the existing housing from the driver door then install in the door handle bezel. The Amazon switch I linked shows the switch and housing for the drivers side door. The switch is held into the housing with 4 clips.
Dorman 901-135 Power Door Lock Switch
Current rides
:canada:
Add to trottida's Reputation
Old 09-12-2017, 11:56 AM   #25
Hey, neighbor - any good ones? The only U-pull type place I know of is in Mason; other places you have to call and ask them to pull
Otherwise, there are places like LKQ in Grand Rapids, or places in and around metro Detroit (there's one off i96 near Brighton, I think, or a bit east of it, that I keep forgetting to check into)
Old 10-09-2017, 04:57 PM   #26
Moon
Default Re: 1997 SL MYSTERIES; Power Locks
Hi. I want to take out my busted power lock buttons on passenger door and replace with a unit purchased on ebay... do I have to remove my door panel to do this? Any other advice is helpful and very appreciated. Thanks.
Old 10-10-2017, 11:07 AM   #27
trottida
trottida's Avatar
No need to remove the panel. The lock bezel is just held in with a tab that you can press in to release and pull out the bezel and switch. Look at the new one to find out if the tab is at the top or bottom so you know where to pry. I'm sure there are YouTube videos.
Current rides
:canada:
Old 10-10-2017, 11:38 AM   #28
step 2 in diagram here
http://www.differentracing.com/tech_...doorpanel.html
IIRC, one Phillips screw, and the tab is towards the rear so slide the assembly forward
Old 10-10-2017, 02:32 PM   #29
trottida
trottida's Avatar
I'm pretty sure you don't need to remove the handle which involves removing the screw and disconnecting the rods. The lock bezel is just snapped into the handle assembly. You just insert a pry tool into the top push the catch down and pop the bezel out towards you. The wiring is long enough to pull the lock switch assembly out, disconnect the wires and put the new one in. Examine the new part to find out where the catch is. I'm thinking the top but check to be sure. It's either top or bottom.
Current rides
:canada:
Old 10-10-2017, 02:42 PM   #30
D'Oh! I'm pretty sure you are right. I might be thinking of a different car (or just confused). Thanks!
If I remember, I'll take a look when I get home tonight. I think I replaced the switch on one of my cars and still have it sitting with a pile of parts.
a parasite of a power drain racinginblood S-Series Tech 29 06-27-2011 06:46 PM
97 Saturn SL1 Power Drain kwiklip S-Series Tech 1 10-30-2009 09:56 AM
1997 sc2 sunroof drain blocked catmandude S-Series General 2 10-23-2005 10:03 AM
Power Door Locks Power Drain robert_vue Vue General 7 05-26-2003 07:52 AM
QC Mysteries -- Anyone in the Know? ducklet Ion General 7 03-18-2003 10:41 AM
