Old 05-13-2003, 01:14 AM   #1
amazinghl
Default How do you connect the power door lock to a car alarm?
I bought an alarm system for my car. I installed it and everything work nice and well. The system is a Audiovox TSP 575 which costed me $30 to get.
The system has an option to hook up to a door lock interface that connect the siren control module to the power door lock system of the car which add on a keyless entry feature so it can lock and unlock the door when the system is being armed and disarmed.
The problem is that NOBODY sells that door lock interface unit. (AA 9158) Or it is VERY expensive.
I feel that I can make a door interface unit myself, I just need to know what parts I need.
There are two wires come out of the siren control module (1 pos and 1 neg, 12v) and they switch from positve to negative and neg to pos depend if the system is armed or disarmed.
Now, I have the power door lock in the car. I took it apart and it has 3 wires. 2 Pos and 1 Neg, 12v. 1 pos (let's call it A) control the locking process and the other Pos (B) control the unlocking process.
What I need is, that a circuit system that controlled by the 2 wires from the siren and can temperory connects A to the Neg when the system is being armed and B connect to Neg when the system is disarmed. I just need them to connect for half a second or so because I don't want to burn out my door lock motors.
So, how do I go about making this unit. What parts do I need, where can I get it, and how much $$$ am I looking at?
Thanks for your time.
94 855 394xxx miles
00 Insight 72mpg
Add to amazinghl's Reputation
amazinghl is offline
Old 05-13-2003, 01:46 AM   #2
wolfman
wolfman's Avatar
Default
Well...I know what you need to do...but don't know how you'd do it. The door lock interface modules for sale have a "logic circuit" that supplies a "pulse" of either neg or pos power (depending on application) to the PDL switch circuit when power is supplied to either the lock or unlock side of the circuit. This "pulsed" (AKA MOMENTARY CONTACT) voltage "fools" the door lock actuation circuit into "thinking" that the power door lock/unlock switch has actually been depressed. The trouble is that the "logic circuit" is a fairly complicated bit of electronics..and as far as I know is not really something someone shy of an electrical engineer could "build" out of Radio Shack type parts. Check out JCWhitney.com..they sell a large selection of alarm system accessories for relatively good prices. They may have what you need at a more reasonable price.
Add to wolfman's Reputation
wolfman is offline
Old 05-13-2003, 08:16 AM   #3
amazinghl
Default
So little fate in me huh?
Hey, if I do build one, that maybe I have the blood of an engineer.
94 855 394xxx miles
00 Insight 72mpg
Old 05-13-2003, 11:49 AM   #4
imtfox
imtfox is on a distinguished road
Default
Actually, you should be able to do it with two relays... look at www.bulldogsecurity.com for some wiring diagrams...
Add to imtfox's Reputation
Rate the quality of this post and help imtfox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
imtfox is offline
Old 05-13-2003, 12:15 PM   #5
amazinghl
Default
What am I looking for in bulldogsecurity?
Actually, if I can find something that can allow me send a pulse from Positive to Ground when they are connected, ONE TIME only *for .2- .5 second or so*. That would do the trick.
Know of anything like that?
94 855 394xxx miles
00 Insight 72mpg
Help!! 1999 SW1 I cant lock my car without the alarm going off after about 10 min marionr26 S-Series Tech 7 04-30-2009 08:15 AM
2006 Strn Vue wiper fluid, Viper starter/alarm, & door lock questions GwenRoka Vue General 1 11-20-2008 06:49 PM
power lock + aftermarket alarm dorisSL S-Series Mods 14 11-03-2008 08:20 PM
What's holding in the power door lock buttons in the door handle? Smokey S-Series Tech 2 09-22-2006 04:52 PM
Connect Alarm to Hatch Donny Mods and Performance 0 11-11-2005 04:31 PM
