Old 01-05-2014, 08:52 PM   #1
Hiddenfarce
Hiddenfarce is on a distinguished road
Default Rogue Hose
Hello all. Iím new to this forum and somewhat new to Saturns although I am a huge GM fan. My wife owns a 2002 Saturn L300 and Iím a t a loss to where this hose connect to. I disconnected it, but after some challenges, the other end of this hose eludes me.
I disconnected it right before I stated to remove the lower intake manifold to continue on my journey to replace the thermostat. Can anyone help?
Hidden
Add to Hiddenfarce's Reputation
Rate the quality of this post and help Hiddenfarce reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hiddenfarce is offline   Reply With Quote
Old 01-05-2014, 11:03 PM   #2
Default Re: Rogue Hose
Follow that hose to its other connection. Is it going to the fuel pressure regulator? It may be a vacuum line from the throttle body to fuel pressure regulator.
Old 01-06-2014, 07:17 PM   #3
mikewiss
mikewiss has a spectacular aura aboutmikewiss has a spectacular aura about
2000 L-Series 3.0L Sedan
That hose goes to the breather crossover duct that bolts on to the upper manifold with the same bolts.(The long flat plastic piece.) The FPR vent hose can be seen just below the FPR. It uses that plastic tubing with rubber couplers.
Mike
Add to mikewiss's Reputation
Rate the quality of this post and help mikewiss reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mikewiss is offline   Reply With Quote
Old 01-06-2014, 07:50 PM   #4
Paradoxmaker
Paradoxmaker has a spectacular aura aboutParadoxmaker has a spectacular aura about
2002 L-Series 3.0L Wagon
1999 SL1
Mike
What is the actual function of this hose. I ask because the one on my car is always full of oil.
Add to Paradoxmaker's Reputation
Rate the quality of this post and help Paradoxmaker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Paradoxmaker is offline   Reply With Quote
Old 01-07-2014, 11:32 AM   #5
Wayne G.
Wayne G. will become famous soon enough
2001 L-Series 3.0L Sedan
There is a flat plastic piece that runs from the front of the intake straight back to the end of the intake (left to right). It is the "PCV" on this motor. Vacuum from the intake to the crankcase. I had to purchase one for my car as it did not have one and a previous owner had simply run a hose across the top of the engine (worked but was not correct). Since your hose is connected already to the crankcase putting the runner back on will be easy. Installing the hose down under was not easy as there is NO room.
Add to Wayne G.'s Reputation
Rate the quality of this post and help Wayne G. reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Wayne G. is offline   Reply With Quote
What Hose Is This? DecayingOmega S-Series General 2 09-18-2006 07:36 AM
PCV Hose sagittae S-Series Tech 8 08-07-2006 06:06 PM
97 SL1Replacing short crimped hose from res to hose assy? Chris0381 S-Series General 1 05-28-2005 01:06 PM
how do I get this hose off? geartooth94 S-Series General 4 10-21-2004 09:54 AM
What's the name of this hose? Spazie Miscellaneous Tech 6 07-18-2004 09:42 PM
