Old 01-03-2014, 08:45 PM   #1
dakota1820
dakota1820 will become famous soon enough
2002 SL
Default Which bulbs for gauge cluster gen 3
So I was told on here that the bulbs I had for my old 98 Saturn would work in my 02 sl. Well they are different. So what aftermarket bulbs can I get that don't cost 4+ per bulb and I need 10 right ?
Also. Everyone says you have to lower the steering column or remove the steering column cover around the steering wheel to remove the cluster that's not the case. If you remove dash pad pop forward the front dash trim and take the bolts out of the cluster says you can easily remove it like that. It's easily a 10 minute job. Not sure why people are lowering the steering column ect.
Add to dakota1820's Reputation
Rate the quality of this post and help dakota1820 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dakota1820 is offline   Reply With Quote
Old 01-03-2014, 09:18 PM   #2
Madness10
Madness10 will become famous soon enough
Madness10's Avatar
Default Re: Which bulbs for gauge cluster gen 3
Lowering the steering column is only for 2nd gen cars. 3rd gen is exactly how you described it. Not sure who told you about the bulbs, but they are not the same as you found out. If you do the search for 3rd gen cluster bulbs in the search, there are a few posts about it.
Add to Madness10's Reputation
Rate the quality of this post and help Madness10 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Madness10 is offline   Reply With Quote
Old 01-03-2014, 09:38 PM   #3
dakota1820
2002 SL
The part number I saw earlier was b8.5d-w is that the correct one? Just want to verify since I was told the wrong thing earlier lol.
Old 01-03-2014, 10:08 PM   #4
Madness10
Madness10's Avatar
As far as I have seen, yes.
Cluster Bulbs? Dennyj1992 S-Series General 10 05-06-2013 08:27 AM
LED Cluster Bulbs Speedrc99 S-Series Mods 47 11-12-2012 06:58 AM
2000 SL2 Gauge Cluster Bulbs (blue)? Maroon97SL S-Series Mods 2 08-20-2011 07:26 AM
Cluster bulbs f3qu3t S-Series General 8 05-07-2006 11:50 AM
removed odometer from gauge cluster, now gas gauge & oil pressure gauge don't work DJboozeAlot S-Series Tech 18 04-06-2005 02:59 AM
