Old 01-01-2014, 09:12 PM   #1
Ilwakeboarder87
Ilwakeboarder87 is on a distinguished road
2004 VUE 2.2L
Default Temp gauge not moving, replaced ECTS, no change...
Hey guys,
First off thanks for some of the tips on here. Been lurking while doing repairs on my Vue and greatly appreciate some of your write ups and knowledge.
I just picked the car up about a month ago and had a couple problems with it. I replaced the hubs, pads, rotors, drums, shoes, stabilizer linkage, tie rod ends, air, oil, gas filter, plugs, ECTS, low speed fan resistor, and a couple other odds and ends.
I have one issue though I'm not figuring out. Pretty mechanically inclined as I can replace engines and transmissions but electrical... Just sucks.
My temperature gauge is staying at 1/4 even when starting the car in -5 temperature. I had to replace the low speed fan sensor as it was completely toast and actually the wire broken. Replaced the ECTS thinking the sensor was bad, no change on the gauge. All other gauges work just fine. Any ideas or places that are common point of failure for the temp gauge? Or could the gauge cluster be toast due to a short in that low speed fan sensor?
2004 2.2L 5 speed
Add to Ilwakeboarder87's Reputation
Rate the quality of this post and help Ilwakeboarder87 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ilwakeboarder87 is offline   Reply With Quote
Old 01-02-2014, 10:29 AM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Temp gauge not moving, replaced ECTS, no change...
Originally Posted by Ilwakeboarder87 View Post
Hey guys,
2004 2.2L 5 speed
Is gauge stuck at 1/4 even with ignition off? If yes - consider replacing the IPC (instrument panel cluster).
Here are a few other things to consider:
All gauge information is provided to IPC on same data-bus.
Here's extract explaining how ECTS information is provided to IPC:
The engine control module (ECM) sends coolant temperature as determined by the coolant temperature sensor to the body control module (BCM) via the controller area network (CAN) serial data. The instrument panel cluster (IPC) displays the engine coolant temperature with the gage when the BCM sends a class 2 message to the IPC indicating coolant temperature percentage. The engine coolant temperature (ECT) gage defaults to cold (0) or below if:
The ECM detects a malfunction in the ECT sensor circuit.
The IPC detects a loss of class 2 communications with the BCM.
The BCM detects a loss of CAN communications with the ECM.
A ECTS failure should activate malfunction indicator light (MIL) - which is also known as service engine soon (SES), or check engine light (CEL) and set diagnostic code P0117.
Many code readers will read live data - plug one into OBD port and check for ECT data (provided in degrees).
See attached thumbnail for ECT sensor interconnect with ECM (near center of diagram).
Old 01-03-2014, 02:00 PM   #3
Ilwakeboarder87
2004 VUE 2.2L
Would your guess be the IPC? You are correct it is at 1/4 even when the ignitions is off.
Btw: thanks for all your help. I see your posts all over with diagrams and such. You're a huge help on this forum.
Old 01-03-2014, 02:51 PM   #4
far2grumpy
far2grumpy's Avatar
I'm thinking its time to go shopping for new IPC (several on eBay and don't overlook local salvage yards).
They are ridiculously easy to swap-out. See post # 5 of this thread for hints:
http://www.saturnfans.com/forums/sho...d.php?t=142173
And, there's few technical obstacles - vehicle mileage is stored in BCM so any IPC you plug in will update after key on.
Thanks for the kind words and I think you'll find most members really try to help.
Old 01-03-2014, 03:04 PM   #5
Ilwakeboarder87
2004 VUE 2.2L
Is there any possibility that the bcm is bad and causing it? Or would there be other symptoms showing up?
Old 01-03-2014, 09:31 PM   #6
far2grumpy
far2grumpy's Avatar
Possibilities are unlimited when dealing with automobiles (or planes, tv's, cellphones, etc).
What I try to do is round up possible suspects and pick the one looking most guilty.
You're obviously shopping for more opinions and hopefully others will chime in.
Old 01-03-2014, 10:41 PM   #7
satlite440
satlite440 is a splendid one to beholdsatlite440 is a splendid one to beholdsatlite440 is a splendid one to beholdsatlite440 is a splendid one to beholdsatlite440 is a splendid one to beholdsatlite440 is a splendid one to beholdsatlite440 is a splendid one to beholdsatlite440 is a splendid one to behold
2001 SL2
the coolant tepm sensor is a 2 wire jump the 2 wires together useing some speaker or other wire and key up the gage should default to full hot if not wireing issue between the connecter and ecm.. if partial id be looking at ipc gage
Old 01-03-2014, 10:45 PM   #8
billysvue
2004 2.2L 5 speed
Add THERMOSTAT to your to do list.
I had the same issue. They get tired/ aren't the best from the factory.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 01-03-2014, 10:46 PM   #9
billysvue
Over-thinking it... Engine temperature is regulated( mechanically) by the....
Jeeez, I missed the part about the gauge frozen at 1/4.... HOw many miles on your VUe, Wake? HOw's the coolant look? FLush it?
'17 Suby Forester
Just replaced thermo, temp gauge at 1/4 spartamouse S-Series Tech 24 04-26-2012 11:17 PM
Replaced ECTS. Temp High. What went wrong? cleazenby S-Series General 24 03-04-2009 12:23 PM
94 SW1 -- ECTS replaced, temp still hot? save_the_expos S-Series Tech 4 08-04-2008 12:03 AM
New ECTS...still have Hot Temp Gauge 2NDSOUT S-Series Tech 6 05-22-2008 09:20 AM
Replaced ECTS... Still runs under 1/4 on temp gauge??? jessicabreck S-Series Tech 13 01-10-2005 11:19 AM
