Old 12-25-2013, 07:27 PM   #1
skpnola
skpnola is on a distinguished road
Post 03 Vue serpentine belt keep breaking!!!
So I have had my 03 Vue since day one. Only had to change oil and tires. It just rolled 100k. The engine (4 cyc) started making a rattling sound but would go away if the AC was on. The other day the belt started smoking and snapped. Thinking it was just old I replaced it and two days later it happend again! Is it a siezed pully? Is the one on the bottom suppose to turn freely? Has this happend to anyone else?
skpnola is offline   Reply With Quote
Old 12-25-2013, 07:57 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 03 Vue serpentine belt keep breaking!!!
I don't have 2.2 but suspect this isn't a common problem.
Three of the four pulley's should turn by hand with belt removed.
Bottom left appears to be crank pulley - will rotate only when engine turns over.
I try to visit forum often but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
Old 12-25-2013, 08:45 PM   #3
skpnola
Post Re: 03 Vue serpentine belt keep breaking!!!
Good to know. I checked and the AC compressor pulley is not moving freely. Can it be removed and cleaned or replaced? I'm getting passed my comfort zone removing engine parts.
Old 12-25-2013, 09:35 PM   #4
far2grumpy
far2grumpy's Avatar
The AC clutch pulley should free-wheel until all conditions are good for the AC compressor to run (engine on, sufficient refrigerant, pressures in-range, etc).
There are service manual instructions for replacing the AC clutch ... too large to post and will certainly require technical skills and a few specialized tools.
Email an address using private message (left click on my screen name) if you want a copy.
A temporary alternative might be to determine the approximate length of a belt needed to bypass the AC compressor.
If illustration I attached is drawn to scale - you might be able to loop a shorter belt around tensioner, alternator and crank pulleys so engine will run.
This could buy time until the AC compressor is needed and/or while yours is being repaired.
Old 12-27-2013, 12:01 PM   #5
skpnola
Thanks for the advice. I measured out 35.5 and wad able to get a 34.5 belt on. At least it will get me through the winter. Thanks again.
Old 12-27-2013, 12:33 PM   #6
far2grumpy
far2grumpy's Avatar
Thanks for posting results - this will probably come up again.
Old 02-13-2019, 06:47 PM   #7
bkunze21
bkunze21 is on a distinguished road
thanks i had the same issue work great
bkunze21 is offline   Reply With Quote
Serpentine Belt without AC cvanloon S-Series Tech 2 08-18-2011 05:08 PM
Serpentine Belt without AC cvanloon S-Series General 2 08-16-2011 02:11 PM
Serpentine Belt replacement & Is belt dressing ok? 2002SaturnMan S-Series Tech 3 02-14-2010 01:37 AM
About serpentine belt and belt tensioner xybaby S-Series Tech 5 01-04-2010 12:42 PM
Timing Belt And Serpentine Belt obsidian52 L-Series Tech 3 06-06-2009 09:23 AM
