Old 12-17-2013, 07:24 AM   #1
dcooke570
dcooke570 is on a distinguished road
Default Fuel Pump Replacement
Anyone have a write-up on replacing the fuel pump on an 2003 3.0 AWD?
Gas gauge is not reading accurately. In the past Chevron Techron fixed it, but this year I have been through 6 treatments with no luck.
Add to dcooke570's Reputation
Rate the quality of this post and help dcooke570 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dcooke570 is offline   Reply With Quote
Old 12-17-2013, 09:58 AM   #2
vasy
vasy is on a distinguished road
2007 VUE Green Line
Default Re: Fuel Pump Replacement
I just did this on my FWD, it was easy, 4 bolts and 5 connectors, but I saw that AWD will be a much bigger PITA.
New pump is $350 new + $175 for the secondary. You can get a used set for $100 (ish) for both or just get fuel level sending unit replacements.
You can also take it apart and just clean the connectors and hope for the best but with AWD I'd at least replace the sending units.
Add to vasy's Reputation
Rate the quality of this post and help vasy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vasy is offline   Reply With Quote
Old 12-17-2013, 10:15 AM   #3
vasy
2007 VUE Green Line
GM instructions:
Old 12-18-2013, 07:12 AM   #4
dcooke570
Thanks for the info and PDFs! I noticed that they mention to remove the drive shaft on the AWD model... I've had it off before and it wasn't too much of a pain but without a lift, not much fun either.
Old 12-18-2013, 03:06 PM   #5
vasy
2007 VUE Green Line
I did mine tank on the jack stands, just had enough space.
Mine is FWD so did not have to pay with the drive shaft. Good luck
Fuel Pump Replacement alanrw S-Series Tech 1 06-08-2010 11:20 PM
Fuel Pump Replacement 95saturn S-Series Tech 6 09-09-2009 01:51 PM
Need help with Fuel Pump Replacement telljody L-Series Tech 1 05-06-2008 10:25 PM
99 S Fuel Pump Replacement (help) snakepit4ever S-Series Tech 2 10-24-2005 04:07 PM
97 Fuel Pump Replacement Nuke S-Series General 1 04-13-2005 11:26 AM
