Old 12-07-2013, 06:54 PM   #1
arizonajones
arizonajones is on a distinguished road
2000 SL2
Default Heavy Vibration in while stopped in 'Drive'
Hi all,
I'm hoping someone might have insight into this:
-The car has intense vibration while sitting still with tranny in Drive. In Park, mild vibration, in Neutral, almost none. I changed the top motor mount less than a year ago and it helped a lot. But the vibration was originally more 'top-passenger' side oriented. Now it feels like its all over - Passenger/driver top/bottom. Now, in addition, it occasionally downshifts while coasting downhill when it shouldn't. -Related/unrelated IDK?
Background info:
2000 SL2 . It's got about 65,000mi on it.
The right front cradle is slightly warped from it whacking a low curb about 9 years ago. It has semi-new spark plugs, fresh oil, tires, serpentine belt, and clean, full tranny fluid. Has no service codes firing. Has not had a tune-up/timing service in a very long time, though.
I was thinking I would change the upper motor mount again, the 2 dogbone mounts and the trans mount and see if that was all it was. BUT... does anyone think it could be something else, before I bother changing mounts? - Torque converter? Timing chain? I'm just trying to decide on the most efficient to-do list.
Thanks!
Add to arizonajones's Reputation
Rate the quality of this post and help arizonajones reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
arizonajones is offline   Reply With Quote
Old 12-07-2013, 08:56 PM   #2
off-track
off-track's Avatar
Default Re: Heavy Vibration in while stopped in 'Drive'
Welcome!
What kind of mount did you replace it with? Many of the part store aftermarket mounts are garbage.
Have you read new or returning owners checklist? Item #12 in the second post details the differences.
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 12-07-2013, 09:31 PM   #3
TomM96
TomM96 will become famous soon enough
The initial post is good advice--
The warped cradle won't help-- might hurt alignment of mounts
On my car {'97SW2 w. TAAT & 196kMi} when i notice occasional rough idle , especially in drive (which is beginning to occur now) , i generally pull the spark plugs , find that one plug has begun to foul , and replace it; and it starts/idles better. I do that about every 6,000 miles.
Add to TomM96's Reputation
Old 12-07-2013, 11:45 PM   #4
SL19302
SL19302's Avatar
2002 SL1
Check the top engine mount for cracking or sag, If you DID NOT use an OEM Saturn mount more then likely thats why your having issues again, Also did you loosen and re-tighten the lower passenger side engine dog bone mount bracket on the engine cradle? Doing this takes the pre-load off the mount and aligns everything correctly.
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 12-20-2013, 10:15 PM   #5
arizonajones
2000 SL2
thanks for the advice, everybody.
I replaced the first one with one from Autozone, which I'm pretty positive was a frowny face.
I found the first gen top mount at Rock Auto so I went ahead and ordered that and the transmission mount (from same manufacturer.) They will be here in about a week, so I'll replace them then and let you know what happens.
Do you think replacing the dogbones is worth it, too?
I also just bought and gapped a fresh batch of NGKs I'll put in this weekend and see if that helps, too.
Old 12-20-2013, 10:37 PM   #6
SL19302
SL19302's Avatar
2002 SL1
I would inspect the dogbone mounts for wear, Theres a good change those are on their way out from the worn top engine mount and trans mount, All four mounts work together and when one gets worn it will stress the other three.
CHECK YOUR OIL!
Old 12-21-2013, 12:33 AM   #7
ssewall
ssewall is on a distinguished road
Since the frowny is basically defective to begin with I'd start with that as others have said.
The dog bones themselves don't really "wear out," it's the rubber bushings that will eventually give. Frankly, in 65k miles I'd have a hard time believing that to be the case unless the car was stored under conditions that would allow them to rot. I'll add that the price of a brand new OE dog bone will knock you out of your seat, and the aftermarket mounts are complete junk. You'll wish you kept the originals. What most people do is replace the bushings once they are worn to that point, that way they can keep the high quality OE strut.
Add to ssewall's Reputation
Rate the quality of this post and help ssewall reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ssewall is offline   Reply With Quote
Old 01-07-2014, 04:16 PM   #8
arizonajones
2000 SL2
Hi all,
quick update:
-Replaced old Autolite plugs with new, properly gapped NGKs. out of the 4, one of the Autolite's gaps was too tight, and one too wide.
-Replaced top motor mount and bottom transmission mount. Good deal on the non-frowny style top-mount at RockAuto.
The vibration is definitely improved, but not totally gone. I'm going to look into getting new rubber for the dogbones eventually.
The only thing not noticeably better is the weirdness with down shifting while coasting downhill (also a short increase in RPMs when braking, before slowing down.)
I'm looking into replacing the ECTS, as I see some threads that relate weird idling issues to them. Sound worth doing?
Thanks.
Old 01-07-2014, 04:54 PM   #9
TXSaturn02
TXSaturn02's Avatar
Thanks.
Since I have a 2002 model, I never messed with it. But most peeps here will tell you yes. Keep in mind that the wire connections on the ECTS tend to be a common issue as well.
New owner As of 01/01/18: 225,000 Miles
As of 01/23/18: 43,635 Miles
Old 01-07-2014, 11:12 PM   #10
arizonajones
2000 SL2
one more quick update on idle wackiness:
now, when pulling into stop in a parking spot its RPMs will shoot up to 3000. This has happened 3 or 4 times in the last 2 days now.
I'm definitely doing the ECTS this week, but is there anything else worth checking that would cause such an extreme jump?
Seems so weird to me that there are no codes firing when something is obviously wrong.
Old 02-01-2014, 02:41 PM   #11
arizonajones
2000 SL2
UPDATE:
I cleaned out the throttle body and idle air control valve (which was coated with carbon) and it no longer sticks while revving.
I saw massive amounts of carbon buildup in the intake, while cleaning the throttle body so I'm looking into some kind of de-carbon cleaning treatment. Maybe Seafoam??? I'm also way overdue for a transmission fluid flush so that's on the way too.
Hopefully I can get to them soon and see how smooth I can get this car to run...
vibration when stopped? Hueyy07 2008 Vue 2 12-14-2013 07:10 PM
Heavy Vibration in while stopped in 'Drive' arizonajones L-Series Tech 0 12-07-2013 06:46 PM
Vibration when stopped in D, but not in R? Silver Gray S-Series Tech 3 06-25-2009 06:25 PM
Heavy engine vibration, checked motor mounts dgreen97 S-Series Tech 2 10-15-2008 11:47 PM
Bottom engine mount, heavy vibration Lukexzx S-Series General 11 12-17-2005 03:44 PM
