Old 12-05-2013, 02:29 PM   #1
jasenpeters
jasenpeters is on a distinguished road
jasenpeters's Avatar
Default Valve Job Advice - 1996 SC2 DOHC
The old 1996 SC2 DOHC (220,000 miles) has been doing well since my last post (2008 clutch change).
A few months ago (Aug 2013) on a long trip from Austin to Houston the engine started running pretty rough at about 100 miles into the trip.
I brought it to a shop and the code and compression check indicated that #4 cylinder (the driver side cylinder), had 10 lbs. of pressure. The remaining valves had pressure in the 190's psi.
From this forum (thank you all), I figured it was a damaged valve.
I pulled the head today and verified that indeed it was an exhaust valve.
#4 cylinder exhaust valve is chipped. (Picture #1)
I found a place (Austin, TX) that would do a "valve job" that includes the following:
$175 - Cleaning, seals replaced, valves bumped or replaced
$45 - Check for cracks
$45 - Resurface head
$11 - per valve replacement ($88 for Exhaust only, $176 for all valves)
Turnaround: 3 days
Does this sound reasonable?
I intend to replace all Exhaust valves.
Should I also replace the Intake valves?
This is only the beginning and I will have more questions as I continue the process.
Thanks in Advance.
Re-Animated: 2015-08-18, 220,497 + 6000 Miles
1996 SC2 DOHC, Manual, 220k, 36mpg Hwy
Add to jasenpeters's Reputation
Rate the quality of this post and help jasenpeters reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jasenpeters is offline   Reply With Quote
Old 12-05-2013, 03:39 PM   #2
billysvue
Default Re: Valve Job Advice - 1996 SC2 DOHC
3 angle grind??????
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 12-05-2013, 04:04 PM   #3
They are always the supposed 3 angle grind.
Just replace the burned valve and get the rest of it. You may lose a couple more in the deal but no reason to throw away good ones. The real problem is to figure out what caused the valve to burn out. Possible low fuel pressure (45-51psi) or dirty injectors, or EGR leaking. What the cause may be depends on what brand of gas you buy and what maintenance has been done.
How fast were you driving when the valve burned out. It is not chipped, it is burned.
Quoted price may be a bit high but if they do quality work I would pay it a saving 25.00 is not that big of a deal and it sounds like that price includes the seals which are about 30.00 alone.
Old 12-05-2013, 04:15 PM   #4
RobertGary1
Would excessive lean (low fuel pressure) or incomplete combustion (dirty injectors) result in a rich/lean DTC?
-Robert
Old 12-05-2013, 04:44 PM   #5
Not usually, it all depends on how fast he was going and how hot it was at the time. It is hot in Texas in August and Austin to Houston can simulate a race track. High speed and high temperature can get you a lean mixture with no warning and by design #4 runs hotter than the other 3 cylinders.
Old 12-05-2013, 04:56 PM   #6
jasenpeters
Old Nuc, what did you mean by...
At the very least, I intend to replace all of the exhaust valves, cost is not a problem. The car has 220 k miles with no previous valve work - I would assume that the remaining exhaust valves are near the end of their life.
Are there any good reasons to NOT replace all of them?
I am ok with not replacing the intake valves unless the shop finds a problem and they need replacing.
As far as why it may have happened, unfortunately at the time the car was burning oil at a higher rate than the past 5-6 years, which was burning a quart about every 1000 miles. In the past year, the rate seems to have increased to a quart about every 500 miles. I did replace the EGR valve with new gasket about 5 years ago and no codes have popped up since the replacement.
Thanks so much for your help, I will keep you updated. More questions to come upon reassembly.
Old 12-05-2013, 05:02 PM   #7
jasenpeters
Thanks for the info about #4 burning hotter by design.
About 5 years ago when I was working on the EGR valve I cleaned the fuel injectors and the throttle body components, and checked the intake sensors.
Old 12-05-2013, 05:06 PM   #8
Would not hurt to repeat that maintenance and get the fuel pressure checked, bring back real numbers not some vague "its OK" written on a work order. Those valves do not wear out from age and if they are actually bad they will replace them as required.
High oil consumption does not help either. You may want to consider just overhauling the entire engine as you are about half done already.
Old 12-06-2013, 05:33 AM   #9
jasenpeters
Can a "rebuild" be done with the block in the engine compartment?
Any references to a rebuild would be helpful, I'll search around too, but there may be some choice ones out there.
I was considering replacing the front seal at least.
Also, I'm looking into the piston mod (drilling holes in the oil ring slot) to
reduce oil consumption.
I will have to weigh the options (time, money, tools, etc) on a rebuild, but will consider it significantly.
Could the front and rear seals be replaced with block in compartment?
To be continued....
Old 12-06-2013, 11:31 AM   #10
billr
Could it be "rebuilt" in the car? Maybe, it depends on what you are calling a "rebuild". However,it would probably be more effort and expense than pulling the engine out.
Add to billr's Reputation
Old 12-06-2013, 02:04 PM   #11
Front yes, rear no, impractical.
Rebuild links. Pay close attention to the cboss remove/replace method.
These 2 threads point out what can go wrong and some things that were overlooked. The problem with ehunters rebuild is the rebuilt head was crap which took almost a year to figure out.
To be continued....
Old 12-06-2013, 02:33 PM   #12
actionstan
actionstan is on a distinguished road
1999 SL1
Would it not be cheaper/easier to buy a already rebuilt head from one of those sellers on ebay? or is that not a good idea?
I found this pretty quickly..
http://www.ebay.com/itm/SATURN-1-9-S...8b987e&vxp=mtr
Add to actionstan's Reputation
Rate the quality of this post and help actionstan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
actionstan is offline   Reply With Quote
Old 12-06-2013, 06:14 PM   #13
The quality of eBay rebuilt heads is poor*. If you can not get one rebuilt locally you will be better off just buying a decent looking used head from a good J/Y.
* poor = incorrect assembly and very high failure rate.
Old 12-06-2013, 06:54 PM   #14
SL19302
SL19302's Avatar
2002 SL1
I would take the current head that was on the car to your local machine shop and let them service it right there in your home town, Buying parts online is a crap shoot especially one that requires dismantling half the engine to replace, If the Ebay head has a problem youll have to do the job all over again its not worth the risk, Just get yours repaired.
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 12-07-2013, 02:46 PM   #15
jasenpeters
Not to worry y'all.
I brought it to a local shop on Thurs. It should be ready next week.
BTW, I got the Fel-Pro gasket set for about $180.00. Too late now, but is that reasonable ?
Gasket kit includes: Head, Valve, manifolds, egr, water pump, etc. the whole shebang
Timing chain questions coming soon....
Old 12-07-2013, 03:08 PM   #16
Basically that sounds OK. RockAuto is pretty much the general benchmark on prices.
Old 12-08-2013, 08:57 PM   #17
spacemanspif
spacemanspif will become famous soon enough
spacemanspif's Avatar
Is the machine shop doing anything to the other half of the head? It might be a good idea to replace/rebuild the lifters, new cam bearings and possibly swap in an intake cam in place of the old exhaust one while they are in there. Just food for thought....
-Mike
1995 SL2 5spd - Stock/MP2 trans swap - 258,XXX miles - 38mpg @ 65mph
1987 Monte Carlo SS - 5.3/4L80E swap - 13.92@103mph - 19mpg @65mph - needs POSI
Add to spacemanspif's Reputation
Rate the quality of this post and help spacemanspif reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spacemanspif is offline   Reply With Quote
Old 05-17-2014, 03:38 PM   #18
jasenpeters
Okay folks, all previous posts were back in December 2013, now its May 2014.
I picked up the "rebuilt" head, which seems to be a valve replacement and cleaning.
I almost cried when I saw how beautifully clean the head was.
As a comparison here is the original condition, head freshly removed.
Now that Spring is here and I have nothing else to do in life (not!), I'm ready to get this old Satty back to running again.
Today, I started cleaning the top of block surface.
So far, I've only used a plastic scaper and some WD-40 and dishwashing soap.
Any recommendations on what type of cleaning solution to use?
Mineral Spirits, Paint Thinner, Degreaser, Brand Names, combination?
Also, I've been using a plastic scraper to work of some of the gasket and gunk. Although, there still seems to be some varnish, etc. left behind.
Any suggestions on what implement to use?
Scotch Brite Scrubby, razor blade, steel wool?
Any suggestions on cleaning the head bolts, or should I replace them?
Also, any ideas on cleaning the thread holes for the bolts?
Thanks in Advance for any advice.
Upcoming, after cleaning....
Surface prep, gasket placement, head placement, bolt turning.....oh my!
Old 05-17-2014, 05:51 PM   #19
Green well used scotch brite and acetone. Once you get the chunks off this will work well.
Old 05-19-2014, 10:25 AM   #20
EHuntress
EHuntress is on a distinguished road
EHuntress's Avatar
The machine shop job looks as good as my own (cleaning job that is).
I used my gun cleaning brushes and cleaners to do the job. Slow and steady, took a while, but it was sparkling.
I used acetone to prep the surfaces for the head gasket as OldNuc has said to use.
I may be buying a car this evening with this problem, so thank you for sharing the picture of the hole in the valve. I'll know when I get the head off, if I'm looking at the same situation or not.
http://thatsaturnchic.wordpress.com
Owner of a 1999 SL2 Saturn (manual trans) purchased Feb 2012
Original 1997 SL2 Saturn owner (manual trans)- rest in peace 6/16/2010
Add to EHuntress's Reputation
Rate the quality of this post and help EHuntress reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
EHuntress is offline   Reply With Quote
Will an 1996 or newer DOhc engine fit in a 95 SC2(dohc)? e dogg S-Series Tech 4 04-04-2008 11:14 PM
Really would appreciate some advice (1996 SW2) jk3006 S-Series General 1 01-04-2006 10:29 PM
selling Port and polished 1996 SC2 DOHC head with valve cover sc2power Classifieds 1 08-27-2003 06:48 PM
Advice, please on sway bar & strut brace advice for 1998 SL2 DOHC. TimothyD S-Series Mods 12 06-21-2002 11:34 AM
Color Change 1996 DOHC valve cover Saturnspeed Classifieds 1 11-06-2001 08:53 AM
