Old 11-23-2013, 05:35 PM   #1
rocket321
rocket321 is on a distinguished road
2000 SL2
2002 VUE 2.2L
Default Shifter linkage clip?
Last night drove home without issues. Got home about to park and reverse is now 4th??? The whole shifting pattern seemed to shift to the right. The shifter now extends further right then it used too and does not go as far left as before. I have the part diagram I lifted from Oldnuc for both shifter links and clips. I'm guessing one of the clips popped off and if it did is there a generic part I can grab off the shelves somewhere?
I was really hoping it was the shifter bushing, but you know... since I have the bushing on hand that I bought over a year ago for the just in case scenarios...
Add to rocket321's Reputation
Rate the quality of this post and help rocket321 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rocket321 is offline   Reply With Quote
Old 11-23-2013, 10:13 PM   #2
colonelhogan44
colonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nice
colonelhogan44's Avatar
Default Re: Shifter linkage clip?
Open it up and have a look under there and see what happened.
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 11-26-2013, 08:23 PM   #3
rocket321
2000 SL2
2002 VUE 2.2L
Did some investigating. The shift tower looked to be in good shape. Also both clips are still in place. Not knowing what to do next, I went to the junk yard to grab a shifter cable housing(?) that sits on top of the trans. Thought maybe something internally was damaged. Got home and did a side by side comparison(while the bad part was still installed on my car). Something didn't look right. Took me few seconds to figure it out.
Close up of first photo.
Haven't installed it yet for a couple different reasons, one of them being questions I have.
What is the torque on the four bolts that hold it in place?
Some crud got inside on removal. Can I spray the inside with brake clean or rinse it with ATF?
If this happens to someone else and you need reverse, it's feasible to put the arm in the correct position by removing the clip for the cable connected to that arm, removing the cable and working the arm into the track again. Be prepared to be thoroughly frustrated because it might pop out one or more times.
Old 11-26-2013, 08:33 PM   #4
Vacuum out the dirt and in the future remove dirt before removing part. You will need a new paper gasket so make one out of a big paper grocery bag. Torque is 18-20 ft-lb
Old 11-26-2013, 08:54 PM   #5
If you got a bunch of dirt in there then flush it down with ATF and change fluid.
Old 11-26-2013, 09:23 PM   #6
rocket321
2000 SL2
2002 VUE 2.2L
Ha! OldNuc you answered one of the more important questions I forgot to ask.
I'll be paper bagging it! Also I was thinking of going ahead and changing out the trans fluid when done.
Old 11-26-2013, 10:55 PM   #7
I would pour a quart over the parts you can see through the hole and then change fluid to get the dirt out.
Replaced clutch but lost a clip for shift linkage.... thejushinator S-Series Tech 11 05-15-2013 09:54 AM
Shifter Cable Clip rnjj1219 S-Series Tech 5 10-05-2012 01:24 PM
shift linkage clip/retainer clip? Need to find one. electricbluevue S-Series General 5 11-13-2010 11:30 PM
98 SL2 Shifter Linkage? wolfehunter S-Series General 13 03-01-2009 07:47 PM
'99 SC1 Shifter Linkage Buck4U S-Series Tech 6 03-20-2008 11:09 AM
