Old 10-23-2017, 08:44 PM   #61
95sohcsl1
95sohcsl1 has a spectacular aura about95sohcsl1 has a spectacular aura about95sohcsl1 has a spectacular aura about
Default Re: 2003 Saturn Vue 3.0L AWD Automatic Transmission Issues
Some info on removing the VB cover. They are Torx 40 bolts. With everything on the top removed as stated above. I removed the lower radiator hose(replacing while it is out) and also removed the front trans mount. Be careful using the torx bit. If the bolts are rusted you might be in trouble. I had one of the bottom ones that was rusted pretty bad and had to remove by notching with a chisel and spinning it with the chisel. The cover will come out the top with some maneuvering.
Add to 95sohcsl1's Reputation
Rate the quality of this post and help 95sohcsl1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
95sohcsl1 is offline   Reply With Quote
Old 10-28-2017, 01:47 PM   #62
95sohcsl1
Well that was a bust! Got the new harness in and tested for resistance and got the same reading so I think was a wild goose chase. Any one have any ideas?
Old 11-13-2017, 11:15 PM   #63
95sohcsl1
Figured I would update this for anyone else looking. So I put everything back together and ordered a TCM off Ebay. Got it back together and cleared all the codes(none were in there), drove it and everything is fine. I don't think I actually fixed anything though since the internal harness checked the same before and after. I drove it about 100 miles and no issues. Got the Ebay TCM and swapped it out and drove around all weekend and no issues. At least I know I have a good TCM to test with when it acts up again. I figure when it acts up I will swap in the "new" TCM and see what happens.
FYI the TCM I got had the same part number as the old one and it swapped fine with no issues. It was one 52.00 shipped so worth it to keep as a test.
Old 12-27-2017, 12:09 AM   #64
karenwarren14
karenwarren14 is on a distinguished road
Originally Posted by far2grumpy View Post
I've attached a few extracts explaining trouble codes - as well as thumbnail diagram for circuit between TCM and auto-trans.
I'm not familiar with this A/T but believe I've read where TCM, or wiring to the A/T (or internal) "may" cause a few of these shorted or open signal problems.
P0700 is probably not a factor as it sets out of sympathy for most other transmission related trouble codes.
Satlite440 - is an active technician / mechanic and usually has good ideas for members. He usually comes online in the evenings.
I had the same problem we replaced the valve body same problem.
took it to a electrical shop he said it was the tcm transmission control modual
found a person who sold them for 150. on the internet. you had to send him all the info. on
the tcm so he could program it for your car . plugged it in and so far it works great
Add to karenwarren14's Reputation
Rate the quality of this post and help karenwarren14 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
karenwarren14 is offline   Reply With Quote
Old 12-27-2017, 12:12 AM   #65
karenwarren14
the tcm so he could program it for your car . plugged it in and so far its
Old 12-27-2017, 12:13 AM   #66
karenwarren14
the tcm so he could program it for your car . plugged it in and so far its works great .
Old 12-27-2017, 12:21 AM   #67
karenwarren14
Originally Posted by heitmeyer10 View Post
Having the same problem on my 2002 saturn vue v6 awd. Just bought this at a auction. I have codes p0700 that won't clear,and p0963 intermittent. Suck in limp mode, and making very had shifts when I manually shift. Any help would be appreciated. I'm leaning towards the tcm, but don't want to throw money away.
Old 12-27-2017, 12:38 AM   #68
karenwarren14
Originally Posted by ThorntonCH View Post
First post after reading some of the forums on this issue. 2003 Saturn Vue 3.0L AWD Automatic 95,000 miles. The Vue has difficulty moving forward in Drive, along with elevated RPM's. At a complete stop, if the transmission is shifted into Low, the Vue accelerates normal through first gear. Moving the shifter then to I or D gives a "hard shift", followed by normal transmission behavior through the remaining gears even up through highway speed. I disconnected the battery, then reconnected 20 minutes later. Went for a test drive, and the transmission acted normal through all gears. At the first stop sign, however, the issues with 1st gear returned while in D. Again, shifting to L allowed, 1st gear was OK. Before and after the battery disconnect, the codes showing up were P0700 (Trans Control Sys Malfunction), P0962 (Pressure Control Solenoid A Control Cirucit Low) & P0966 (Pressure Control Solenoid B Control Cirucit Low).
Purchased the Vue for little more than scrap value. No Saturn dealerships close, but the local GM/Toyota dealership quoted the previous owner $2K+ in repairs to replace the valve body, seals & labor with the disclaimer that the repairs might not solve the issue. Thoughts anyone?
Old 12-27-2017, 11:20 AM   #69
95sohcsl1
Sorry , I never updated this. It did act up again and I put in the eBay TCM and immediately it was fine. I have put over 300 miles on it so far with no issues. Fingers crossed it fixed it!!
Automatic transmission issues jaekl S-Series Tech 5 06-12-2008 12:45 PM
Automatic Transmission Issues - Part II timbob S-Series Tech 4 07-25-2007 12:23 PM
Automatic Transmission Issues timbob S-Series Tech 25 07-09-2007 03:12 PM
95 SL2 automatic transmission issues mercuris S-Series Tech 3 03-28-2007 12:07 PM
2003 ion automatic transmission fix? Dan Pressly Ion General 3 07-07-2003 04:30 PM
