Old 11-24-2014, 09:57 PM   #41
Chazberry
Chazberry's Avatar
Default Re: 2003 Saturn Vue 3.0L AWD Automatic Transmission Issues
Originally Posted by spyderr911 View Post
Does anyone have a walkthrough PDF or video of how to do this on a 2003 Saturn Vue 3.0? Also if I buy a new (or used/rebuilt) valve body, does it come with the 3 solenoids, or am I confusing things again?
I haven't seen procedures for the R&R of this VB, but if you get a rebuilt, it will come with the Solenoids - they are an integral part of a VB.
Add to Chazberry's Reputation
Old 11-24-2014, 10:21 PM   #42
Chazberry
Chazberry's Avatar
Geezus - is there anything that is NOT on Youtube!?
http://www.youtube.com/watch?v=PrAe4XBzENc
Of course it's always easier with the tranny on the bench!
But poke around Youtube - there seems to be a wealth of info.
Search AF33 and AW55.
Old 12-13-2014, 01:19 PM   #43
cvt critic
cvt critic is on a distinguished road
Hi everyone I have a 03 vue 2.2L with af23 trans that I successfully installed using jimmie 504,s instructions about a year ago,my wife has been driving it ever since without any lights on or any problems at all till the other day when she slammed on her brakes to keep from t boneing and old man that pulled out in front of her,when she started to pull back out the service engine came on and she only had 5th gear,she limped it on home so I could work on it,I scanned it for codes and got po963,I took the neg bat terminal loose and touched it to the pos terminal for a few minutes and it fixed it for about 2 days then the code set again ,this time I cannot clear it.i put another trans and wiring harness in it and there's no change,the service engine light is still on solid with code po963 and jerks when put in reverse or drive just like before,could this be the tcm or tach/app causing this ,can i test the tcm somehow,surely I didnt get a bad trans and wiring harness with the same exact problems,thats the only code I get no matter what i change, anybody had this problem,any help would be much appreciated.
Add to cvt critic's Reputation
Rate the quality of this post and help cvt critic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cvt critic is offline   Reply With Quote
Old 12-13-2014, 01:57 PM   #44
Chazberry
Chazberry's Avatar
This thread is about the Aisin AF33. Go here and hit the 'New Thread' button on the left and put AF23 and P0963 as the subject line . . .
http://www.saturnfans.com/forums/forumdisplay.php?f=35
Old 12-13-2014, 04:04 PM   #45
Chazberry
Chazberry's Avatar
Also maybe a new thread here, since I think that's the only Saturn that came with the AF23 . . .
http://www.saturnfans.com/forums/forumdisplay.php?f=37
Also take a look at this thread . . .
http://www.saturnfans.com/forums/sho...d.php?t=170761
Old 12-18-2014, 02:01 PM   #46
spyderr911
spyderr911 is on a distinguished road
Ok, so here is where I am now. I took the Saturn to my mechanic friend who tested the Transmission cable (pin 2 and 9, and then 2 and the others). After going through that list (you attached earlier in this thread), he believes it is the TCM.
So I guess I will try to replace the TCM first, before moving on to something else (like valve body).
Quick question... I've read that the TCM has to be programmed for the VIN # of the car. Is this true? And if so, and I buy a VIN programmed TCM, is it plug-and-play at this point, or do I need to go through some shift adapt relearn process or anything to make it work properly?
Add to spyderr911's Reputation
Rate the quality of this post and help spyderr911 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spyderr911 is offline   Reply With Quote
Old 12-18-2014, 04:48 PM   #47
Chazberry
Chazberry's Avatar
At least it's easier than getting into the VB.
I'm not sure about the VIN programming, but I'm thinking all these VUE TCMs have the same calibration. If so, it looks like you can adapt your replacement TCM to your VB with these procedures . . .
Old 12-18-2014, 06:02 PM   #48
spyderr911
Thank you for these instructions.
The reason why I was asking if the TCM needed programming is because most eBay auctions mention it. Take a look at this auction, and notice the "IMPORTANT" part roughly halfway down the listing:
http://www.ebay.com/itm/VIN-PROGRAMM...-/400805554888
I'm not sure if the seller is just trying to scare the public (i.e. me) into thinking that it won't work any other way, just so he can sell a few more units over the other auctions online.
Any thoughts on this? Any other threads on this forum where people have had success replacing the TCM without having it 'programmed' with their VIN #? There are much cheaper used TCMs on eBay besides the one this guy is selling.
Old 12-18-2014, 06:49 PM   #49
Chazberry
Chazberry's Avatar
In this thread that I referenced in Post #30 . . .
http://www.saturnfans.com/forums/sho...d.php?t=184001
Taylorham420 replaced his TCM, but he didn't reply to the programming question. Maybe try PMing him.
Old 12-18-2014, 09:31 PM   #50
Chazberry
Chazberry's Avatar
pacocase got a JY TCM - didn't say anything about programming . . .
http://www.saturnfans.com/forums/sho...d.php?t=198918
Old 03-17-2017, 09:37 AM   #51
natenatenate
natenatenate is on a distinguished road
New here and sorry for reviving such an old thread. Just wanted to say that this particular thread (combined with some similar ones) helped me. I just purchased a 2002 Vue 3.0 awd auto, that had transmission problems exactly as you guys have described. I replaced the TCM and it's back on the road again! So thank you for all the information in this thread!
Add to natenatenate's Reputation
Rate the quality of this post and help natenatenate reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
natenatenate is offline   Reply With Quote
Old 10-18-2017, 08:14 PM   #52
95sohcsl1
95sohcsl1 has a spectacular aura about95sohcsl1 has a spectacular aura about95sohcsl1 has a spectacular aura about
Piggy backing on this old thread hoping to get some help. Mine is an 03 Vue, AWD V6 auto. Has 160k miles. A few months ago on the way home from Alabama to MO it acted up in Memphis. Same symptoms as above. Trans clunk, in limp mode, not reduced power mode. Basically stuck in high gear. I looked on here and checked the connector under the kick panel. It was corroded, I cleaned it, reset the codes and it drove great all the way back to Kansas City and have been driving it every since. Fast forward to today, it started doing the same thing. I pulled the connector, cleaned it, put connector grease, reset the codes but now it does not fix it. It will immediately set the P0700 and P0963 codes and stuck in high gear.
If I could get the info from the service manual like the info above that would be great so I can pin test to see if I can narrow down the problem. Any help is appreciated!!
Add to 95sohcsl1's Reputation
Rate the quality of this post and help 95sohcsl1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
95sohcsl1 is offline   Reply With Quote
Old 10-21-2017, 10:52 PM   #53
far2grumpy
far2grumpy's Avatar
See attached FSM extract ... 3.0 / P0963 ... repost or send PM if you need others.
Old 10-21-2017, 11:12 PM   #54
95sohcsl1
Figured I would add to this in case anyone else runs across this thread. You can access the plug on the trans to run the check by removing the battery, the 4 bolts that hold the batt tray/fuse box holder down. Unbolting the coolant overflow bottle and moving it out of the way. Unclip the TCM and move it and its holder out of the way. Pull the plastic batt tray/fuse box holder up and towards the fire wall(you dont need to remove it completely). Then remove the metal tray under the plastic batt tray. Once all this is done you have access to the plug. Unplug it.
I used some small alligator clips to clip to the #4 terminal, then bent the probe on my multi meter to touch the other terminals as needed. Helps to have a mirror in place to see the terminals.
Old 10-21-2017, 11:13 PM   #55
95sohcsl1
Thanks, I had found that one in some other threads I wonder if the 03 procedure is the same as the 02?
Old 10-22-2017, 10:09 AM   #56
Chazberry
Chazberry's Avatar
Probably - those 2 years were almost identical.
Old 10-22-2017, 10:14 AM   #57
95sohcsl1
Far2grumpy said that was from the 2003 extract. According to the pin test I have a problem with the internal wiring harness in the trans. I did notice trans fluid inside the connector which I thought was weird. Going to pull the VB cover today.
Old 10-22-2017, 10:23 PM   #58
95sohcsl1
Got the VB cover off and got a harness ordered. I didnt see anything wrong with the old one bit worth a shot. Not real confident it is going to fix the problem.
Old 10-23-2017, 12:07 PM   #59
Chazberry
Chazberry's Avatar
How was the resistance on the Solenoids?
Old 10-23-2017, 12:16 PM   #60
95sohcsl1
The reading between 4 and 11 was 6.5 so I went to check resistance between 4 and all the others and could not get a reading on any of the pins but 11. So basically no continuity between 4 and any of the others except 11. Hopefully I am interpreting it right!
Automatic transmission issues jaekl S-Series Tech 5 06-12-2008 12:45 PM
Automatic Transmission Issues - Part II timbob S-Series Tech 4 07-25-2007 12:23 PM
Automatic Transmission Issues timbob S-Series Tech 25 07-09-2007 03:12 PM
95 SL2 automatic transmission issues mercuris S-Series Tech 3 03-28-2007 12:07 PM
2003 ion automatic transmission fix? Dan Pressly Ion General 3 07-07-2003 04:30 PM
