Old 11-07-2013, 04:11 PM   #1
Moskvitch
Moskvitch has a spectacular aura aboutMoskvitch has a spectacular aura about
Moskvitch's Avatar
2000 SL2
Default Rear disc brake swap parts
Hi all,
I was looking forward to pulling some rear calipers to do the rear brake conversion on my 2000 SL2. I headed over to my local junkyard, didn't have any S-Series with rear discs. Called all the junkyards in my city; none of them will sell me calipers as they consider it a safety concern.
Is my only option to go new? Or does anyone have some they can sell me? I get parts at cost through my school so i could get it there.
I priced it all out:
Fenco semi-loaded calipers #SLC8326 & SLC8327 for 72$ each
Dorman parking brake cables #C95198 (x2) 30$ each
Wagner Thermo-quiet pads (set of 4) 45$
and then i need the brackets... no idea how im gonna get those.
Does that seem right? is that all i need?
Add to Moskvitch's Reputation
Rate the quality of this post and help Moskvitch reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Moskvitch is offline   Reply With Quote
Old 11-07-2013, 07:19 PM   #2
tunedbysaturnsl
tunedbysaturnsl is on a distinguished road
Default Re: Rear disc brake swap parts
Brackets, you should be able to order from Auto Zone or Advanced Auto or Rock Auto. Rear dust shields are suggested, but many say they're not required. I think the brackets run about $30.
As for your rear disc swap project, I'm planning on doing the same at some point next year. I know there's an SC2 in a junkyard close to me with disc brakes on it that I'll be snagging tomorrow pending weather. I get to try out my new impact gun I specifically got for this task of junkyard hunting. I'm gonna disassemble them, powder coat, and then rebuild with new inserts and pads come spring time. Hoping the dust shields are in fair condition as well. Not worried about the rotors since I'll be getting new ones for the rear when I do the front as well.
Kind of funny how your local junkyards won't sell you calipers because of a safety concern. Most junkyards know people will use them as trade-in cores or rebuilds instead of installing them straight onto a car. But, I suppose it makes sense.
1995 Saturn SL1 "Abby"-Powertrain Swap Completed. Running As Of 07/27/2013
1997 Mitusbishi GST "Phoebe"
Looking For:
Saturn Blimp plush
Homecoming Saturn Logo "Lost Form Cast" piece
Add to tunedbysaturnsl's Reputation
Rate the quality of this post and help tunedbysaturnsl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tunedbysaturnsl is offline   Reply With Quote
Old 11-07-2013, 09:02 PM   #3
Moskvitch
Moskvitch's Avatar
2000 SL2
I think i may just head out to the other junkyard across town and pull the brackets and cables, if i explain to the guy that i just want cores he may let me have them.
Old 11-07-2013, 09:13 PM   #4
Chub
Chub will become famous soon enough
Chub's Avatar
When I did my rear disc swap I got the cables, calipers, and brackets out of a '95 SC2 at the junkyard. They had no issue selling them to me. It was quite cheap for all of them but they were pretty rusty. I then found out that Advance Auto Parts had remaned calipers with brackets for sale at $30 + $30 core. I then traded in the old ones for cores on the rebuilt ones. The most important part is to make sure that you end up getting the appropriate e-brake cables. Also I am not running a dust shield on mine and it is working fine. The parts you have in your list should be all you need. Just make sure you put thread locker on the rear wheel knuckle to bracket bolts. I had one of them come off on me while I was driving and it was not a fun experience.
1995 SC2: Back on the road again after my second engine rebuild in two years.
Add to Chub's Reputation
Rate the quality of this post and help Chub reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chub is offline   Reply With Quote
Old 11-08-2013, 01:31 PM   #5
tunedbysaturnsl
Well, just got home from the junkyard to get rear disc brake swap parts. Didn't have any luck. Both of the cars that had disc brakes were on the ground (ie no wheels and nothing sitting under them). Couldn't manage to get calipers off and they were quite rusted regardless. Unfortunately, the dust backing shields looked in decent condition.
Anyway, decided I'd just go and bite the bullet and buy some "new" re-manufactured ones at Advanced Auto Parts. They had both right and left rears listed in stock. I figured new seals, new piston, new hardware, and they were already clean so, it was probably worth it. I managed to get only one though-the right rear by Fenco. The left side was only the caliper, no mounting bracket. I was like, okay, maybe a mix-up at the factory. Went to the other store about 5 miles or so away. Same damn scenario! No mounting bracket. So, the fella at the store was going to try Fenco, but didn't have any luck getting in touch with them. I left my name and number since he'd see what he could do for me. Got in touch with him and he said he can order one from Cardone and have it in about a week.
So, heads up and a rule of thumb! Check the box for the bracket and hardware before you leave the store even if the part numbers match! Seems that Fenco maybe be phasing out of brake calipers or at least, the mounting brackets. (Which I don't understand since it says that the caliper and bracket must be returned for core credit on the box of my right one).
The rear calipers seem to be so expensive for the critters they are.
At least my junkyard trip wasn't a total waste. Managed to get a replacement for my power lock key cylinder switch thing that goes behind the driver's door key lock. Even though, I lost my Torx socket.
Looking For:
Saturn Blimp plush
Old 11-08-2013, 01:46 PM   #6
SL19302
SL19302's Avatar
2002 SL1
I did the conversion on my 02 SL1 over the summer the conversion is all bolt on and go the biggest pain is the park brake cables you need to get cables off of a 96-98 with rear discs, The last year for the Rear Disc option was 98, parts needed are:
1. Calipers WITH Bolts, and Purchase NEW PADS, and NEW ROTORS.
2. Caliper Brackets WITH Bolts
3. Both Rear Emergency Brake Cables off of a rear disc equipped car.
4. Rear Disc Brake Hoses, BOTH sides, Alot say they are optional GET THEM, as suspension travel stresses the current drum hoses.
5. Dust Shields, Optional I didnt use them as they usually are rotted and no longer avaliable through GM.
CHECK YOUR OIL!
Add to SL19302's Reputation
Add/swap to rear disc brakes BigSexy S-Series Tech 8 10-16-2012 06:14 PM
Rear Disc Swap 99GreenySC2 S-Series Mods 19 03-09-2012 12:40 PM
3rd Gen brake bleed problems after rear disc swap SL1Guy S-Series Tech 9 09-11-2010 06:53 PM
2nd Gen Rear Disc Brake Swap: 1st gen brakes fit? TIMSPEED S-Series Tech 4 02-19-2008 12:06 AM
Rear disc swap hints! sps SOHC S-Series Mods 54 09-30-2006 10:39 PM
