Old 11-04-2013, 01:08 PM   #1
bnc
bnc is on a distinguished road
Default 1996 SL1 Steering Rack: Power & Manual same part??
Howdy--
I need to replace the steering rack/pinion in my 1996 SL1 (Manaul Steering), and the guys at autozone are telling me that Part # 64113 on their website (sorry, I can't post actual links here yet) will work. It's listed as a power steering rack though. Are the power and manual racks indeed the same part for my car??? Doesn't sound right to me.
Thanks a bunch, and have a great day.
--Brad
Add to bnc's Reputation
Rate the quality of this post and help bnc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bnc is offline   Reply With Quote
Old 11-04-2013, 01:30 PM   #2
Default Re: 1996 SL1 Steering Rack: Power & Manual same part??
You might be confusing them by giving them the wrong model number/name, the steering rack is about the only thing where the difference between SL and SL1 truly matter. You have a SL, not a SL1.
You need AZ part number 6878 for the least amount of headache's.
#64113 will bolt to everything except the steering column just fine, and you'll have to either re-rebuild it to be a manual rack, add a PS pump, bracket & belt, or pour enough ATF into the rack and a custom loop-able line to fill it for proper lubrication. To make it fit onto the column you'll have to find (in a junkyard) the U-Joint connecting the two, they are different on the rack side and not swappable.
Old 11-04-2013, 01:41 PM   #3
trottida
trottida's Avatar
Interesting that the manual steering parts are more expensive then the power steering. Supply and demand I guess.
http://www.autozone.com/autozone/par.../N-j4ze9Z8oxk3
Current rides
:canada:
Add to trottida's Reputation
Old 11-04-2013, 03:21 PM   #4
bnc
Well heck, it is an SL. That was probably the hitch. Thanks for straightening me out. I'll go ahead and get the correct part and just get things done. The price difference really is nuts between the manual and power steering! I always figured stick with manual to keep things cheep and simple.
Thanks again!
Old 11-04-2013, 07:17 PM   #5
bnc
These guys had a much better price:
shop.rackdoctor.net/SATURN_c19.htm?gclid=CJTpkcytzLoCFa47MgodeFgACQ
Steering rack Manual kjtyo4 S-Series Tech 2 03-19-2010 09:14 PM
Converting power steering rack to manual... Craig S-Series Mods 14 05-11-2007 10:44 AM
power steering leak/steering rack question Gadweller S-Series Tech 9 11-19-2005 02:18 PM
FS: Manual Steering Rack amazinghl Classifieds 0 12-04-2004 01:57 AM
ProDarwin, or anybody knows anything about the Manual Steering Rack, please help. amazinghl Miscellaneous Tech 13 02-25-2004 05:03 PM
