Old 11-03-2013, 09:47 AM   #1
rjames711
rjames711 will become famous soon enoughrjames711 will become famous soon enough
Default Enlarged section of exhaust do anything?
Hey guys. 99 sl2 here. So the other day my exhaust broke off right behind the flange which is in back of the cat. A little after that flange there's an enlarged section of pipe. At both ends of this enlargment its pretty badly rusted so I was thinking of cutting the whole thing out and replacing it with regular pipe. My question is does this enlargment do anything for performance? Thanks
Add to rjames711's Reputation
Rate the quality of this post and help rjames711 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rjames711 is offline   Reply With Quote
Old 11-03-2013, 09:50 AM   #2
Tommie
Tommie is a jewel in the roughTommie is a jewel in the roughTommie is a jewel in the rough
1996 SL1
2002 SL1
Default Re: Enlarged section of exhaust do anything?
The resonator? Helps shape the sound...probably ok to straight pipe it. The SL1 aftermarket pipe deletes it...
Add to Tommie's Reputation
Rate the quality of this post and help Tommie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tommie is offline   Reply With Quote
Old 11-03-2013, 10:10 AM   #3
rjames711
Yah I guess that would be the resonater. I tried taking a picture but somethings wrong with my phone.
Old 11-03-2013, 11:00 AM   #4
rjames711
Wow I just cut it out and I'm really suprised by all the stuff inside it. Like this weird bumpy helix thing. I feel kinds bad deleting it although it looks like part of it is loose.
Old 11-03-2013, 11:18 AM   #5
billr
Deleting it won't affect emissions, and won't change exhaust sound too much. Have you checked price on a replacement resonator?
Add to billr's Reputation
Old 11-03-2013, 12:19 PM   #6
mattwithcats
mattwithcats will become famous soon enoughmattwithcats will become famous soon enough
Either another resonator or a glass pack muffler will work.
Cherry Bomb 87520 - 2 inch inlet/outlet
87521 - 2 1/4
87522 - 2 1/2
2002 Silver SL2, manual, 5th gear swap (.605), 78,000 miles, black badges,
Pennzoil Ultra Platinum 5W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 11-03-2013, 02:33 PM   #7
rjames711
Thanks guys, I ended up just replacing it with a 3 foot section of 2 inch exhaust pipe. Its sounds a little more obnoxious now but I really needed to fix it asap and as cheap as possible. If it hadn't broken right at the flange I probably would have soup canned it until I had more time and money to do it nicely. Either way it all welded up now so at least I have my car back!
Old 11-03-2013, 07:42 PM   #8
Macgyver
Macgyver has a spectacular aura aboutMacgyver has a spectacular aura aboutMacgyver has a spectacular aura about
The resonator removes exhaust rasp and “popping” noise when you left off the throttle rapidly. Installing a resonator rather than just pipe wouldn’t have been much more expensive. Probably less then $50.
Add to Macgyver's Reputation
Old 11-03-2013, 07:51 PM   #9
SL19302
SL19302's Avatar
2002 SL1
Interesting, I noticed on my SW2 theres a resonator right after the converter and on my SL1 theres no resonator at all just a regular 2 inch pipe all the way back to the muffler, They both have the original exhausts, Did saturn drop the resonator at some point?? My Wagon is a 2000 and the SL1 is an 2002??? Or was the resonator used only on the Twin cam models???
Add to SL19302's Reputation
Old 11-03-2013, 09:24 PM   #10
Macgyver
No, it was just a cost saving measure. SOHC engines do not have the resonator.
SCCA Section aperseghin S-Series General 9 05-10-2007 07:57 PM
Exhaust front flexpipe section 93goldsl2 S-Series Tech 0 05-31-2006 11:53 AM
Polls Section karinhesed86 Community Center 0 01-17-2006 01:38 AM
'how to' section? 1993 S-Series Tech 2 01-02-2005 12:59 PM
Enlarged Throttle Body cookitup Mods and Performance 13 11-05-2002 03:42 PM
