Old 10-29-2013, 06:47 PM   #1
gnmike87
gnmike87 is on a distinguished road
Default 2007 XR Headlights Flickering
I have searched on this issue and keep hitting brick walls. Both low beam HID headlights will flicker and eventually go out. You can re-ignite them by cycling the switch off and then on but they will go out again after a few minutes. I have visually inspected the wiring connectors that some people have posted being melted and they look just fine. I doubt that both headlights are actually bad and going out at the same time. I am leaning more towards and electrical problem somewhere. The alternator output is good. I am trying to test for AC voltage at the battery and am coming up with .5mv, Does anyone know if this an acceptable amount of ac voltage? Any ideas or suggestions would be greatly appreciated.
Add to gnmike87's Reputation
Rate the quality of this post and help gnmike87 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gnmike87 is offline   Reply With Quote
Old 10-29-2013, 10:30 PM   #2
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
Default Re: 2007 XR Headlights Flickering
light switch???
Add to onefunkar's Reputation
Old 10-30-2013, 12:39 AM   #3
Alternator a/c ripple should be less than 0.5 volt, making your 0.5mv (millivolt) well below then maximum. You should know that measurement is made at the B+ terminal on and alternator frame for optimum reading.
Are Aura's using stock HID lights or is this a mod?
Old 10-30-2013, 07:19 AM   #4
gnmike87
They are stock headlights. I will recheck the voltage at the alternator. I was checking it at the battery. I don't believe it's the switch, I have a feeling it's more in the ballast modules or the electrical somehow.
Old 11-02-2013, 11:27 PM   #5
Doug C
Doug C's Avatar
2008 Outlook XE
Idea Re: 2007 XR Headlights Flickering
Did ya not get the special warranty upgrade done on them ?
I don't recall the specifics, will chk file to see if I still have my letter.
nite,
doug c
Add to Doug C's Reputation
Rate the quality of this post and help Doug C reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-05-2013, 06:53 AM   #6
gnmike87
No, I have called the dealer to check for any open warranty or recalls. No such luck.
Old 11-11-2013, 02:06 PM   #7
Doug C
Doug C's Avatar
2008 Outlook XE
Attention Re: 2007 XR Headlights Flickering
Hmmm maybe not a '07 thing, but here is (hopefully attached) my letter originally sent out dec.2011 , deadline for repairs dec 31,2013
good luck
doug c
p.s. yep, i cropped out letterhead & personal data !
2007 Aura XR Headlights.... emonnier Aura General 5 05-23-2011 10:25 PM
fog lights flickering singgirl17 S-Series Tech 1 09-15-2008 10:56 AM
95 SL1 Dash lights/headlights flickering - vehicle dies Poker Face S-Series Tech 3 01-12-2008 05:09 PM
Question about flickering headlights skunk333 L-Series Tech 8 03-13-2007 08:41 PM
The last word on flickering headlights sattech L-Series General 31 04-30-2004 10:18 PM
