Old 10-24-2013, 02:39 PM   #1
ottergrey
ottergrey is on a distinguished road
Default 2003 Saturn Ion ignition replacement
Replaced bad ignition switch due to bad tumblers (new switch, same key.) After reassembly, passlock icon on dash is lite. most threads say to either reset computer or passlock itself. Neither choices work (10 minutes on, 5 -20 seconds off.) Passlock icon does not flash as per all threads, but stays lite. Vehicle has 98,000 miles, and started perfectly before switch change. Vehicle sat idle for 4 months before I replaced the switch. Battery is fully charged.
Add to ottergrey's Reputation
Rate the quality of this post and help ottergrey reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ottergrey is offline   Reply With Quote
Old 10-24-2013, 03:23 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: 2003 Saturn Ion ignition replacement
The ignition switch has no tumblers. Did you replace the switch or the lock cylinder? It's spelled light...
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 10-25-2013, 11:46 AM   #3
satlite440
satlite440 is a splendid one to beholdsatlite440 is a splendid one to beholdsatlite440 is a splendid one to beholdsatlite440 is a splendid one to beholdsatlite440 is a splendid one to beholdsatlite440 is a splendid one to beholdsatlite440 is a splendid one to beholdsatlite440 is a splendid one to behold
2001 SL2
try the 30 minet relearn...at the bottom
Service Information
2003 Saturn ION | ION VIN A Service Manual | Body and Accessories | Theft Deterrent | Repair Instructions | Document ID: 1701021
Programming Theft Deterrent System Components
Important:
•If replacing the BCM with a GM Service Parts Operations (SPO) replacement part, the module will learn Passlock™ sensor data code immediately. The existing PCM however, must learn the new fuel continue password when the BCM is replaced.
•If replacing a PCM with a GM SPO replacement part, after programming, these modules will learn the incoming fuel continue password immediately upon receipt of a password message. Once a password message is received, and a password is learned, a learn procedure must be performed to change this password again. A PCM which has been previously installed in another vehicle will have learned the other vehicle's fuel continue password, and will require a learn procedure after programming to learn the current vehicle's password.
ConditionsUse this procedure after replacing:
•Passlock™ Sensor
•BCM
•PCM
Learn ProceduresThere are 2 available methods to perform the programming procedure:
•A 10-minute procedure which requires a Tech 2 and a techline terminal.
•A 30-minute procedure which does not require the use of any tools.
10-Minute Learn ProcedureTools Required
•Tech 2
•Techline terminal with current Service Programming System (SPS) software
 1. Connect the Tech 2 to the vehicle.
 2. Connect the Tech 2 to the Techline terminal.
 3. Turn ON the ignition, with the engine OFF.
 4. Following the instructions on the Techline terminal, select the appropriate vehicle information.
 5. On the techline terminal, select “BCM Learn” .
 6. Select the appropriate transmission and BCM type.
 7. The Techline terminal will program the BCM and then start a 10-minute countdown.
 8. Do not disconnect the Tech 2 until the 10 minute countdown is complete.
 9. Observe the SECURITY telltale. After approximately 10 minutes, the telltale will turn OFF. The vehicle is now ready to relearn the Passlock™ Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK.
10. Turn OFF the ignition, and wait 30 seconds.
11. Start the engine. The vehicle has now learned the password.
12. With the Tech 2 (scan tool), clear any DTCs.
30-Minute Learn ProcedureImportant: Do not remove the key from the ignition during this procedure. If the key is removed, the procedure will have to be performed from the beginning.
 1. Turn ON the ignition, with the engine OFF.
 2. Attempt to start the engine, then release the key to ON. The vehicle will not start.
 3. Observe the SECURITY telltale. After approximately 10 minutes, the telltale will turn OFF.
 4. Turn OFF the ignition, and wait 5 seconds.
 5. Repeat steps 1–4 two more times for a total of 3 cycles/30 minutes. The vehicle is now ready to relearn the Passlock™ Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
Important: The vehicle learns the Passlock™ Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
 6. Start the engine. The vehicle has now learned the Passlock™ Sensor Data Code and/or password.
 7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles.
Old 10-25-2013, 08:39 PM   #4
snakes
snakes has a spectacular aura aboutsnakes has a spectacular aura about
snakes's Avatar
2005 ION-1 Sedan
Thumbs Up Re: 2003 Saturn Ion ignition replacement
great info to know ! Thank you for posting
Add to snakes's Reputation
Rate the quality of this post and help snakes reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
snakes is offline   Reply With Quote
Ignition Lock Cylinder Replacement 2004 Saturn Ion Mike89 Ion Tech 2 09-10-2013 08:48 PM
2003 Saturn Vue 3.0 V6 seal replacement Jelawman Vue Mods 0 12-03-2012 11:05 PM
2003 saturn ion ignition problem Master Frank Ion Tech 2 09-20-2011 07:12 PM
2000 saturn sl ignition lock replacement. sparrow2004 S-Series Tech 2 07-15-2009 09:10 PM
2003 Saturn Vue Brake Replacement mmaynard Vue General 3 10-28-2008 07:57 PM
