Old 10-22-2013, 04:13 PM   #1
2002SATURN-PHX
2002SATURN-PHX is on a distinguished road
2002 SL1
Default High Idle Issue
Hello all, I've been noticing something really strange. If I drive my car for any long distance, like constant with little stopping after about 20 miles or so when I come to a stop my idle is way up and stuck at about 1200 or 1400 on the tach. It never does it on a short distance run like to the store and back. Any ideas what this could be. Sounds like maybe a sticky TPS ?? Thanks for any help with this .. Also if I turn off the car and pump the gas pedal two times and then restart it, it's back to normal idle at about 700 ???
Add to 2002SATURN-PHX's Reputation
Rate the quality of this post and help 2002SATURN-PHX reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2002SATURN-PHX is offline   Reply With Quote
Old 10-22-2013, 04:20 PM   #2
SL19302
SL19302's Avatar
2002 SL1
Default Re: High Idle Issue
If you shut the car off when the high idle occurs and re-start it and returns to normal, it usually indicates a bad TPS sensor, However being you have the 00-02 SOHC check also for an intake leak at the number 1 cyl intake runner where it meets the cylinder head as the intake gaskets are faulty on those engines and also could lead to a high idle situation.
Add to SL19302's Reputation
01 SC1 High Idle Issue Grenjar S-Series Tech 3 08-28-2010 06:02 AM
High Idle Issue HELP! jay11789 S-Series Tech 3 05-25-2010 05:36 PM
97 with high idle issue tiger saturn S-Series Tech 2 04-07-2007 09:14 PM
High Idle Issue jjseiler13 S-Series Tech 0 02-06-2007 10:06 AM
High Idle Issue... Neo Ion General 6 01-18-2005 01:51 PM
