Old 10-16-2013, 07:11 AM   #1
ddeuces22
ddeuces22 is on a distinguished road
Default gm 12346141 or rtv for timing cover
OK I've seen quite a bit of people using rtv. I've used the ultra grey without issues in the past, also used ultra black. I can pickup some new old stock gm 12346141which is recommended. Should I give the gm stuff a try? Price is similar either way.
96 sl2 stage 1 midpenn cams,91/92 header,2.25 ss exhaust, ported and polished head, groundpounder, sda bones, pimped tranny mount, .40 o/s pistons, .25 u/s rods, .25 u/s crank,19mm progress swaybar
Add to ddeuces22's Reputation
Rate the quality of this post and help ddeuces22 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ddeuces22 is offline   Reply With Quote
Old 10-16-2013, 07:48 AM   #2
Default Re: gm 12346141 or rtv for timing cover
Permatex The Right Stuff in the caulking gun tube or cheeze whiz can. Put in a refrigerator for 24 hours before using to give you more assembly time. Use 2 studs at the top to hang the cobver on and a reversed crank sprocket to align the oil pump gear and do enough dry runs that you can hang the cover and push it into place in 2 minutes or less.
sounds like the timing chain coming in contact with timing cover prioris S-Series Tech 3 12-08-2012 12:12 AM
timing chain sounds like it could be coming into contact with timing cover prioris Sky Tech 0 12-07-2012 09:31 PM
What problems can be diagnosed / fixed under the valve cover / timing cover? Dalamar S-Series Tech 1 09-15-2011 08:42 AM
Timing Cover gfreek1 S-Series Tech 2 07-29-2006 05:45 PM
timing cover emailer33 S-Series General 22 03-28-2005 09:54 AM
