Old 10-15-2013, 09:08 AM   #1
Vue Daddy
Vue Daddy is on a distinguished road
Default Random Heavy Front End in Shake when Brakes applied
I have some front brake issues. I have a 2004 VUE FWD 3.5L I bought new and now have approximately 334K miles on it. Just finished another timing belt and water pump.
I have front brake issues. I upgraded rotors and pads from EBC this summer because of the situation. Everyone has said warped rotors forever. However, in October 2012 I changed out pads/rotors and the pads barely looked used. I assumed warped rotors. There is a major shake of the front end when brakes applied at times. It seems random too.
The only consistency I can find is that I have never replaced the Right Rear ABS Sensor which I know has been bad for two years. I was curious if that might have anything to do with it? I have the sensor and ready to replace it anyway. I just can't believe some of my front pads have looked like little wear when replacing. And I replaced thinking warped rotors.
Any thoughts would be appreciated.
Add to Vue Daddy's Reputation
Rate the quality of this post and help Vue Daddy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Vue Daddy is offline   Reply With Quote
Old 10-15-2013, 10:28 AM   #2
billysvue
Default Re: Random Heavy Front End in Shake when Brakes applied
does the speed(s) at which you notice the shudder ever occur in the same range?
guesses : worn tie rod ends, maybe cupped/worn front tires and/or hub bearings..
ANy new suspension components up front?
swaybar bushinngs links, struts?.
Have you jacked up the front/set on stands and tried to shake/move stuff?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 10-15-2013, 01:01 PM   #3
Vue Daddy
"I have not noticed anything similar about speed range...That is what stumps me..."
"I started wondering about the tie rod ends as well....New tires recently can't be it...one new bearing but this was an issue before bearing started making noise earlier this summer..."
"I put new bar end links on a couple of years with no issues. "
" I have not jacked it up and shook anything yet. I think that is what I will do though now. I might buy new Stabilizer Bar bushings and end links too to take care of that occasional clunking. "
Old 10-15-2013, 01:42 PM   #4
far2grumpy
far2grumpy's Avatar
Billysvue posted good thoughts - including questioning condition of tires.
Do you feel pulsating brake pedal when front end shakes?
If problem is rotor related - more often caused by deposits from brake pads than warped rotors - pulsing will be present most anytime brakes are applied.
I can't make a case for anything sway-bar related as most drivers wouldn't know the difference if the sway bar is disconnected from struts.
I think I'd look a little deeper since you have 334,000 miles on the little guy.
The top of struts (and mounts) are anchored to body through the strut towers and everything else is tied to the engine/transmission/suspension "cradle" which is held to body/frame by four large bolts.
If shake only happens randomly my prime suspects would be things that wear out such as struts and mounts, ball joints, control arm bushings, tie rod ends, etc.
I think you would be on right track if you elevated the vehicle and used a pry bar to test movement of spindles with relation to control arm and steering linkage.
Its especially important to make sure the "cradle" is solidly in place. I've found cradle bolts with a good percentage of shank rusted away and another member actually had to replace the cradle due to severe corrosion (rust).
Old 10-16-2013, 09:29 AM   #5
topcat
topcat will become famous soon enough
topcat's Avatar
Mine developed a brake shudder above 40mph; when I inspected the brakes the pads looked almost new. Swapped out the rotors and the shudder went away. Note; the condition of the hub is crucial in how long the rotors will last as any corrosion will cause run out and leave deposits from the pads on them and the shudder will be back. The lesson: if the hubs aren't true the rotors won't be true(ie run out will be excessive). Best.
Add to topcat's Reputation
Rate the quality of this post and help topcat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
topcat is offline   Reply With Quote
Old 10-17-2013, 10:27 AM   #6
FINCH
FINCH is on a distinguished road
2004 VUE 3.5L
I have always spent a little more on the rotors and pads and got the heavy duty ones due to the fact that i find the cheap ones are too thin or just can't handle the heat while braking of the vehicle. It seems the brakes are beefy enough for the vehicle it was made for. Kinda like my old Caravan. A little now or a lot later i guess.
As for the pulsating, if the front end it tight, and happens when you apply the brakes and feel it in the steering wheel then it is more than likely the rotors.
Good luck and let us know what you find out.
Add to FINCH's Reputation
Rate the quality of this post and help FINCH reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FINCH is offline   Reply With Quote
Steering vibration when brakes applied hydromech S-Series Tech 6 05-21-2011 06:10 PM
Hard brakes, Climb in rpm when brakes applied motodan S-Series Tech 7 05-17-2010 09:22 PM
Click in Shifter when Brakes Applied danf L-Series General 4 12-22-2005 03:44 PM
96 sw2 stalls when brakes applied jmorrell S-Series General 2 05-31-2005 02:38 PM
Random misfire (P0300) under heavy load 98greenSC2 S-Series Tech 11 03-03-2005 01:06 AM
