Old 09-15-2013, 07:20 PM   #1
SomethingClever
SomethingClever is on a distinguished road
Happy P0410 final solution
I thought that I had conquered my P0410 secondary air system fault code, but after a couple months it came back. I decided to create a new thread so everyone can see my final solution. To see the history of my problem go here:
http://www.saturnfans.com/forums/sho...=1#post2009536
I went ahead and replaced the diverter valve which unfortunately did not solve the problem. I got another blower, which also did not solve the problem. I rechecked everything else and found nothing wrong.
Long story short, I ended up having to remove the exhaust manifold and clean out the air intake ports on the front of the engine. I had done this once before, but I didn't realize how deeply the carbon build up went into the ports. I posted a video here:
https://www.youtube.com/watch?v=E6z0d_AuKY8
I think the problem is solved once and for all now. I hope this helps others.
This code can be a nightmare, especially if your area has emissions inspections that require no trouble codes in order for your car to pass... like mine.
Add to SomethingClever's Reputation
Rate the quality of this post and help SomethingClever reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SomethingClever is offline   Reply With Quote
Old 09-15-2013, 07:33 PM   #2
cleverbot
cleverbot is on a distinguished road
cleverbot's Avatar
1994 SC2
Default Re: P0410 final solution
Fyi that is an SC2 not an SC1 as stated in your other thread. The 2 stands for twin cam.
Very nice informative video btw.
1994 Saturn SC2 (5-speed) with 240k. (RIP Junked 11/16/12)
1993 Toyota Tercel STD (4-speed) (sold)
1998 Saturn SL2 125,000 miles (RUNNING FANTASTIC!!!)
2012 Chevy Sonic 26,000 miles (5-speed)
Add to cleverbot's Reputation
Rate the quality of this post and help cleverbot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cleverbot is offline   Reply With Quote
Old 09-15-2013, 07:37 PM   #3
SomethingClever
Thanks. I've read a lot of posts where people have struggled with this code for the exact same reasons I have. I thought the video might help.
Old 09-15-2013, 07:47 PM   #4
cleverbot
cleverbot's Avatar
1994 SC2
Unfortunately Saturn motors like there carbon build ups.
Old 09-16-2013, 02:46 AM   #5
Macgyver
Macgyver is a glorious beacon of lightMacgyver is a glorious beacon of lightMacgyver is a glorious beacon of lightMacgyver is a glorious beacon of lightMacgyver is a glorious beacon of lightMacgyver is a glorious beacon of light
How many miles are on your Saturn? I'm wondering how long it takes to build up carbon to the point of cleaning out the exhaust manifold.
Add to Macgyver's Reputation
Old 09-16-2013, 08:00 AM   #6
BV22
BV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of light
2002 SC1
Mine were packed solid when I cleaned them around 160k. They are partially plugged again at 220k, as I get a P0410 every now and then, but it goes away on its own.
Cleaning the air passages in the head on a DOHC is a real PIA, as they are curved. On the SOHC, they are straight holes that can easily be cleaned with a drill bit spun by hand.
BV22
2002 SC1 5M
313k 07/18
Add to BV22's Reputation
Old 09-16-2013, 08:20 PM   #7
SomethingClever
140,000 miles and counting, but i first had to clean the steel tube at about 120k.
Old 01-11-2014, 03:04 PM   #8
herkyc130
herkyc130 is on a distinguished road
I had the same everything with everything working but when I put compressed air to blow out the exhaust manifold the pending code went away when the engine was already hot, so I do not have enough air flow with the cold start is what I think even though the pump is blowing good
Add to herkyc130's Reputation
Rate the quality of this post and help herkyc130 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
herkyc130 is offline   Reply With Quote
Old 01-11-2014, 04:28 PM   #9
TXSaturn02
TXSaturn02's Avatar
Who is this Richpin everyone speaks of? Well, mine was solved by replacing the diverter valve - its been about 18 months ago and I haven't had trouble with the code returning. Thanks for your input.
New owner As of 01/01/18: 225,000 Miles
As of 06/15/18: 49,365 Miles
Final drive? KDulcimer S-Series Tech 6 11-07-2011 12:26 PM
P0410 Code Solution Shared Ditchwizard S-Series Tech 2 10-25-2011 07:18 PM
Final straw Please help matt93sat S-Series Tech 13 04-14-2005 11:20 AM
scR final, final, final garage sale teamscr Classifieds 0 11-08-2004 10:43 PM
