Old 08-15-2013, 07:43 AM   #1
Donp_101
Donp_101 is on a distinguished road
Attention Auto-Transmission Light/Failure 06 Ion 2.2 L
I drive the car, it drives fine, then the trans light comes on and the trans "fails". If I restart the car, it will ocassionally clear and drive fine. Hasn't done this in awhile since before yesterday.
Any ideas what it could be?
When it "fails" it shifts very hard and doesn't accelerate much at all.
104240 miles, had trans flush/filter change @ 98000 miles.
Add to Donp_101's Reputation
Rate the quality of this post and help Donp_101 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Donp_101 is offline   Reply With Quote
Old 08-15-2013, 08:15 AM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Auto-Transmission Light/Failure 06 Ion 2.2 L
Is the check engine light, or service vehicle message on?
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 08-15-2013, 11:05 PM   #3
ED3
ED3 is on a distinguished road
Hmm tough one. First let me ask a dumb question. Are you sure everything was connected and put back where it belonged when the did your trans oil and trans oil filter change?
Add to ED3's Reputation
Rate the quality of this post and help ED3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ED3 is offline   Reply With Quote
Old 08-16-2013, 07:40 AM   #4
Donp_101
So I'm not sure if everything was connected correctly when they did the flush. Also, the check engine light comes on and goes off, and the last code I had read to me was a misfire code. I will take it to Autozone this weekend first thing and get another reading.
For the misfire stuff, I changed the ICM, coil pack, and boots. I had previously changed the plugs to iridium plugs at 75k approx. I am going to try and change the fuel filter and o2 sensor. I don't have access to fuel pressure test so if push comes to shove and those don't do the trick, I'll replace the fuel pump. I already pump the intake with carb cleaner a few times and have run multiple tanks of premium w/ injector cleaner every so often.
Back to the problem. Should I check out the tranny control module or solenoid? I know for a fact the trans is working correctly mechanical, so I would assume its an electrical fault of some sort...
Anyone know where I can sell my Ion!?...
Old 08-20-2013, 10:19 AM   #5
Donp_101
UPDATE:
Misfire:
I replaced to O2 sensor and it seems to be running a little better. Haven't driven it to work and back yet, so can't give a good definite.
Trans:
Tranny hasn't "failed" again lately. Don't know what to do now. Replace Tranny control module?
VTI Transmission Failure- No GM Help jprice30 Community Center 0 09-01-2011 10:05 AM
Transmission Failure tamccain Outlook General 2 10-30-2009 09:28 AM
1995 SL1 Auto. Tranmsission Failure Bryan3 S-Series Tech 43 09-13-2005 02:33 PM
HELP! SL2 @ 37K Transmission failure & more Annabelle General Saturn Discussion 5 06-28-2005 07:40 AM
Sl1 TRANSMISSION FAILURE Wayne Smith S-Series Tech 6 01-11-2003 08:32 PM
