Old 08-04-2013, 03:58 PM   #1
Norseman
Norseman is on a distinguished road
Default Need to close sunroof stuck in vent position
My sunroof is stuck open and I would like to close it one more time and leave it.
I've searched the forum and could not quite find the answer. I took the map light and headliner down. It doesn't look like there is a manual screw to close the sunroof.
The motor works. At first both rear sides stayed up. After running the motor close and pressing down on the driver's side of the sunroof, that corner has come down. However, the passenger side is still stuck up.
I don't want to repair/replace...just close it once and for all.
Please help.
Thanks.
Add to Norseman's Reputation
Rate the quality of this post and help Norseman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Norseman is offline   Reply With Quote
Old 08-04-2013, 04:08 PM   #2
sallydriver
sallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to all
sallydriver's Avatar
1993 SW2
Default Re: Need to close sunroof stuck in vent position
The guides probably broke. It's a known issue. There are people who sell stronger replacements.
But, for temporary use, what I did was drop remove the glass and muscle the guides closed (rearward) then reinstall the glass.
1998 Red SL 5spd "The Right Honorable Duke Farnsworth the Functional of Clearfield":165,000 miles
1999 Forest Green SL2 5spd "Sally": 307,100+ miles
1993 White SW2 5spd "Steve": 234,984 miles
Add to sallydriver's Reputation
Rate the quality of this post and help sallydriver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sallydriver is offline   Reply With Quote
Old 08-04-2013, 10:55 PM   #3
dougalldc3000
dougalldc3000 is on a distinguished road
I feel your pain, luckily I got an aftermarket replacement with metal guides so I'm good to go. Saturn made a mistake putting plastic guides in a sunroof that has large surface area...
Anyway, if it's in the vented position you can get a long screwdriver and try to pry the plastic pieces sticking up (holding the glass up) towards the rear of the car to put them down, thus putting the glass down.
Hope this helps.
'99 SL2 5-spd DOHC 1.9L 4 cyl w/ lots of mods
'13 Dodge Dart 6-spd 1.4L MultiAir Turbo
#StrictlyAmerican
Add to dougalldc3000's Reputation
Rate the quality of this post and help dougalldc3000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dougalldc3000 is offline   Reply With Quote
Old 08-04-2013, 11:38 PM   #4
Norseman
Hope this helps.
Since I don't know where and what the guides look like, I'm going to remove the glass per Sallydriver (I've found the torx screws) and look for these guides. Do I just push them down with my finger?
Old 08-04-2013, 11:42 PM   #5
sallydriver
1993 SW2
That's what I had to do. I wasn't home, so it was tough.
Old 08-05-2013, 10:20 PM   #6
dougalldc3000
If what you're talking about is getting the glass down once it's in vented position, the picture I attached shows the plastic pin holder type thing that you need to pry down in the red circle.
Actually, contrary to what I said before, I think you would need to push lower part of it to the front of the car to drop the glass into place.
Let me know if there's any more confusion.
#StrictlyAmerican
Old 08-05-2013, 10:23 PM   #7
dougalldc3000
The guides run along the sides of the sunroof assembly, once you take the glass off they're not hard to miss
#StrictlyAmerican
Old 08-06-2013, 11:20 AM   #8
Norseman
Thanks for the picture. I'm going to work on it this weekend. Good thing it's still summer.
Old 08-06-2013, 09:23 PM   #9
dougalldc3000
Glad I could help man! Yeah I wasn't able to replace mine until last May, wish I could have used it during spring though
#StrictlyAmerican
Old 08-10-2013, 06:19 PM   #10
Norseman
I was able to close the sunroof.
Old 08-10-2013, 06:25 PM   #11
Norseman
Old 08-10-2013, 06:31 PM   #12
Norseman
I removed the glass, power the sunroof to the closed position, and then used a large flat blade screwdriver and hammer to tap the back of the guide forward.
I disconnected the power wire so the sunroof doesn't get accidentally opened.
Thanks again to sallydriver and dougalldc3000!!
***Sorry for the multiple posts...browser kept quitting when submitting reply ***
Old 08-11-2013, 12:10 AM   #13
sallydriver
1993 SW2
Glad to hear you got it closed. Also glad to help.
When mine broke, I didn't even know this forum existed.
It was pouring rain too, so I had to figure all that out while soaked in a dress suit.
Old 08-11-2013, 12:26 AM   #14
sallydriver
1993 SW2
Attention Re: Need to close sunroof stuck in vent position
If you ever want to repair your sunroof, check these guys out. They explain why the sunroof fails, and what their solution is. I've heard nothing but positive things about them, and their fix is a permanent one.
sunroof vent position saturnsctwo S-Series Tech 9 08-22-2011 12:12 PM
2001 sc2 sunroof vent position saturnsctwo S-Series Tech 1 06-25-2011 05:24 PM
Recirculating vent stuck Tortooga S-Series Tech 4 01-15-2008 03:30 PM
95 SL2 Sunroof will not close bwholl S-Series Tech 1 05-16-2007 04:11 PM
Sunroof Emergency: Stuck in "raised" position CND_SC1 S-Series Tech 0 09-11-2006 03:23 PM
