Old 07-16-2013, 02:07 PM   #1
up north
up north is just really niceup north is just really niceup north is just really niceup north is just really niceup north is just really nice
1999 SW1
1999 SW2
Default EGR valve bolt broken
Good day
I decided to clean my EGR valve on my 98 SL1 and broke the furthest bolt, leaving just a bit of it stiking out, so I heated with acetylene torch around the bolt, PB Blasted it and with my bolt extracting kit I proceded to do so (extracting) but it would not give, my luck my extracting bit broke in the bolt. So my next course of action for me is to bring the car to my favorite mechanic and let a pro do the work. Leaving as is, the motor rev's up to 4100 RPM, so I put back the EGR with a new gasket, tighten the remaining bolt and used a pair of vise grips to hold down the other end. Still the RPM went up. I then tried to block the EGR passage as RICHPIN's soda can trick video. Still the RPM went up. I find very hard to believe that with the remaining bolt and vise grips I have a seal leak on my EGR. Is their an other condition that will make it rev up besides the lack of an EGR valve?
Add to up north's Reputation
Rate the quality of this post and help up north reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
up north is offline   Reply With Quote
Old 07-16-2013, 03:05 PM   #2
LabRat
LabRat is on a distinguished road
Default Re: EGR valve bolt broken
Unrestricted vacuum leak, such as that open EGR port, will cause the over-rev.
-LR
Add to LabRat's Reputation
Rate the quality of this post and help LabRat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LabRat is offline   Reply With Quote
Old 07-16-2013, 06:27 PM   #3
up north
1999 SW1
1999 SW2
Thanks for the reply LabRat, I have a bluetooth OBD2 reader with torque software on my android phone. The realtime info gives me -20 PSI at 4100 RPM, I also see the throttle moving when I press the pedal. I got the codes P0522 and P1599.
If I have a vacuum leak where should I check for it
Old 07-16-2013, 07:31 PM   #4
LabRat
First place I'd look is where the intake manifold or plenum may have been affected by working on the EGR valve and bolt. If there are no obvious leaks try the spraying along gasket(s) with brake or carb cleaner trick. Also, be sure you've ruled out leakage past the broken bolt. Good Luck!
-LR
Old 07-16-2013, 07:43 PM   #5
The P522 is not a valid code for a 98 or 99 Saturn. The 1599 is a simple stall. If you used an torch on the aluminum EGR flange it is probably distorted and the gasket will never seal.
Old 07-16-2013, 08:28 PM   #6
up north
1999 SW1
1999 SW2
Sorry OldNuc the code was P0562, no link to my problem here, I went easy on the torch, not at all near red hot, just got it very hot, i did not get the sizzeling of PB Blaster when it is sprayed on near red hot iron, just some smoke. I pushed a side the fuel line and kept the flame small and moving a lot so I would not melt or burn any plastic around that area. Putting the valve on its platform it feels flush all around. I do'nt think at least I hope the valve platform was not warped. I did not have a tin can laying around so I used 8 layers of tin foil ( folded 3 times) and a thin piece of cardboard before bolting and vise gripping the valve over it. At daylight I'll inspect the area more carefully. About the reading of -20 PSI I got from the real time data of the Torque software, would that indicate that my vacuum is good. And I should concentrate on the EGR open port.
Old 07-16-2013, 09:25 PM   #7
That is -20 inches Hg vacuum and is good. Get some sheet metal as aluminum foil will not last 15 minutes. You should not need a clamp either even pressure to hold it down will work. The 562 is low system voltage. Charge the battery completely and you may be rid of the high idle.
Valve cover bolt broken off.....:( bsgaggero S-Series Tech 10 05-10-2009 01:33 PM
Broken Valve Cover Bolt fquan59 S-Series Tech 21 10-28-2008 07:53 PM
96SL2, broke a valve cover bolt, how to remove the bolt? HomeBase S-Series Tech 6 04-20-2008 11:35 AM
Broken bolt valve cover pilothale S-Series Tech 7 09-15-2007 11:05 PM
Broken Bolt - TB Red97sc2 S-Series Tech 7 02-13-2005 06:59 PM
