Old 07-12-2013, 06:09 PM   #1
Pete68W
Pete68W is on a distinguished road
2005 ION-2 Sedan
2009 Astra XR
Default I think I fried the computer
while trying to jump my 2005 ion (left the lights on, d'oh!) i was jostling around the jumper cables, and when i went to start it, i got an "error" message on the display and the it totally died. it's a manual and it wont even go with a push and pop the clutch. it tries to run but it just sputters and dies, and none of the lights on the display come on. do you folks think i fried the computer or could it be a fuse?? thanks so much!
Add to Pete68W's Reputation
Rate the quality of this post and help Pete68W reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Pete68W is offline   Reply With Quote
Old 07-12-2013, 06:40 PM   #2
Default Re: I think I fried the computer
Did you try looking for blown fuses first? They're there for a reason and mistakes with booster cables can blow fuses.
Where did you boost from, engine side or trunk? Leaving lights on doesn't cause problems other than a slight battery drain. There's a RED designated battery post (covered?) in the engine area for jump starting. Battery negative on the engine block.
Old 07-12-2013, 07:13 PM   #3
2006 ion2
2007 ION-2 Sedan
These cars can't be pop started unless you disable passlock by fixing the key, it requires enough juice to try starting the engine without killing the electronics. Check your fuses, probably fried computer(s)
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 07-12-2013, 07:29 PM   #4
Pete68W
2005 ION-2 Sedan
2009 Astra XR
Update!!! I let it sit for an hour or so, to let it (and myself) cool off. Went back, turned the key, got a little power back, jumped it the rest of the way with the gf's van, and now it's purring like a kitten! I guess it just had a little tantrum and needed to reset itself. I appreciate all the input though! Thanks again!!!
Could I have fried my EGR valve? beaverplt S-Series Tech 6 01-15-2012 09:55 PM
computer fried? flyboyjake S-Series Tech 10 04-18-2010 11:54 PM
Fried PCM or perhaps BCM? Jinjo S-Series Tech 9 05-10-2009 09:58 PM
Compressor is fried Tryin2FixIt S-Series General 4 06-23-2006 11:45 AM
Ack! I think I fried my BCM... LB_BlueVue Vue Tech 11 05-02-2006 05:27 PM
