Old 07-03-2013, 11:31 AM   #1
travisj027
travisj027 is on a distinguished road
travisj027's Avatar
2002 SC1
Dizzy Saturn SC1 2002 RH Headlight Assembly Repair/Removal
Today a yellow pole appeared from the sky and struck my car.
It busted my passenger side headlight (not to oblivion) but enough for it to need to be replaced before inspection. I have already ordered the part but I am having trouble finding a video on how to replace it correctly. I did find this thread on the forums:
http://www.saturnfans.com/forums/sho...d.php?t=133800
Basically I disconnect the battery terminals (positive & negative) then I disconnect the terminals that hook onto the lights? Remove the 2 screws then it just comes off?
I'm just making sure, so I'm ready to go when the part comes in. Seems simple, 15 minute DIY job? Any feedback is greatly appreciated. Thanks in advance!
-Trav
Also the pole did some minimal damage to my front bumper (good thing it's plastic) can I just knock out the dents with a rubber mallet back into place? Thanks!
Help me make my Saturn the best running of it's class!
Add to travisj027's Reputation
Rate the quality of this post and help travisj027 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
travisj027 is offline   Reply With Quote
Old 07-03-2013, 02:07 PM   #2
TXSaturn02
TXSaturn02's Avatar
Default Re: Saturn SC1 2002 RH Headlight Assembly Repair/Removal
I purchased aftermarket ones from Amazon recently and installed - it was much easier than I thought. Do a search on headlight assembly and a thread I started. I didn't touch the battery. It is just two 10mm bolts. After undoing the bolts, slide it forward (towards you) and then up/inward. Do one at a time so that you can use the other side for reference. I'm glad I replaced mine - they look MUCH better and I'm sure I'll be able to see better. I have noticed, however, that I need to adjust them. Hopefully that will not be too tough. Turn right goes up or down?
New owner As of 01/01/18: 225,000 Miles
As of 06/15/18: 49,365 Miles
Old 07-03-2013, 05:22 PM   #3
Yes, turning right goes up or down (no idea but if you're paying attention you'll notice within a half turn)
No reason to touch the battery. Wouldn't even need to open the hood if it wasn't hiding the bolts
Old 07-03-2013, 11:16 PM   #4
travisj027
travisj027's Avatar
2002 SC1
Thanks for the input guys. If I don't need to touch the battery then I'll just disconnect the 3 terminals to the lights. Pull it forward and upward toward me! Doesn't sound too difficult at all!
Old 07-04-2013, 08:47 PM   #5
TXSaturn02
TXSaturn02's Avatar
Turning right, the light goes up.
2002 Headlight Assembly TXSaturn02 S-Series Tech 15 06-28-2013 02:39 AM
2002 sc2 headlight assembly mounts dak1957 Support Forum for Canadian Saturn Owners 0 03-16-2013 02:29 PM
2002 L300 Rear Axle Bearing and Hub Assembly Removal admiralbrown L-Series Tech 4 07-02-2012 08:06 AM
Saturn ion 4dr sedan Headlight assembly Rendall89 Ion General 4 06-24-2012 11:12 AM
2001-2002 SC2 headlight assembly removal greencoupe02 S-Series General 1 08-11-2006 08:59 AM
