Old 06-17-2013, 07:17 AM   #1
kevo420
kevo420 is on a distinguished road
kevo420's Avatar
2000 SC2
Default Water leaks into car
Hi,
Last week I had my interior out and found the passenger side floor pan had a considerable amount of water in it. There was a grey foam type material in the footwell running up the firewall that was pretty saturated. It seems logical that the water is entering either behind that foam or higher up the firewall.
I didn't have a chance to try and remove that foam but with all the rain we've been having lately I know there's probably more water making its way into the car and need to takle the leak.
Do these cars have a common place they let water ingress into the car?
Add to kevo420's Reputation
Rate the quality of this post and help kevo420 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kevo420 is offline   Reply With Quote
Old 06-17-2013, 07:49 AM   #2
Default Re: Water leaks into car
If you have a sunroof, the drains like to clog up and build up water. The front ones are behind the outer kickpanels, you have to remove the door-jam cover and pull out a rubberish plug with a wire harness on it to get to the drain and then pull the drain out to clean it (while allows the water to drain).
Another common spot if the water is from the middle of the car is a leaking heater core (accompanied by a sweet/coolant smell) or the A/C drain. The A/C drain is around where the shifter cable(s) come through the firewall, located in the engine bay. A pipe cleaner or maybe a pencil works for cleaning it.
My '96 leaked water and air around the windshield, I put some RTV on the gap between the windshield & roof...solved both problems in one go
Old 06-17-2013, 11:12 AM   #3
Highmile
Highmile's Avatar
Another place to check is around the condensate drain for the air conditioner.
It is sealed with the same foam rubber you saw and it deteriorates over time. I resealed mine with rtv between the drain tube and the firewall.
So far so good.
Highmile
'95 SL1 518k and counting
Add to Highmile's Reputation
Old 06-17-2013, 11:19 AM   #4
BV22
BV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of light
2002 SC1
Yet another common source is the cabin air inlet under the hood up near the windshield on the passenger side. It should have an elliptical donut seal on it. It this is cracked, dry rotted or missing, the cabin will take in water.
BV22
2002 SC1 5M
305k 02/18
Add to BV22's Reputation
Old 06-17-2013, 06:07 PM   #5
lamping.ap
lamping.ap will become famous soon enoughlamping.ap will become famous soon enough
+1 fetchitfido. Check your coolant level. And pull the sunroof drain hoses out of their fitting, if you have them. I've had both leak on me.
Add to lamping.ap's Reputation
Rate the quality of this post and help lamping.ap reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lamping.ap is offline   Reply With Quote
Old 06-17-2013, 08:27 PM   #6
hholbein
1997 SW2
This would be one of the first and easiest items to check, and a very common failure point given the adhesive dries out on the foam donut/mesh sandwich of the vent cover. Easy to fix too -- just reglue with something more permanent, like clear silicone caulk.
The other posts are also very real possibilities but involve a bit more work/sleuthing around.
Add to hholbein's Reputation
Old 06-18-2013, 05:59 AM   #7
kevo420
kevo420's Avatar
2000 SC2
Thanks for the pointers, I believe I found the problem last night.
This seal was missing. I likely knocked it off when I swapped my motor a couple weeks ago. Thankfully I have a parts car that still had this seal, I RTV'd it to the body. Rained last night and i didn't feel much dampness on the carpet, but the plastic-like coating on the underside of the carpet makes it hard to tell. I'll have to remove the carpet this weekend and see.
Thanks
First gen water leaks??? mobleysuede S-Series General 4 04-25-2013 07:36 PM
WATER LEAKS - Please Help ! hydromech S-Series Tech 5 12-02-2012 08:29 AM
If your still having water leaks..... khansen30 Outlook General 2 10-09-2008 03:59 PM
Water leaks!!!!!!! kleiss33 S-Series Tech 1 05-16-2008 01:13 PM
Water Leaks??? FalconXR Outlook General 3 06-09-2007 05:05 PM
