Old 06-13-2013, 08:18 AM   #1
driveguy
driveguy is on a distinguished road
Default 2003 Vue AC/Heat mixer not working
I have 2003 Vue and mixer is no longer switching to the floor. AC and heat works fine, but set the knob to floor and the mixer doesn’t divert. Ideas? Links to solutions?
Thanks in advance.
Add to driveguy's Reputation
Rate the quality of this post and help driveguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
driveguy is offline   Reply With Quote
Old 06-13-2013, 08:05 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 2003 Vue AC/Heat mixer not working
Thanks in advance.
The typical 02-04 HVAC module has four actuators.
Two are accessible from right side of module - these are outside air and panel (face) actuator - remove glove box to access.
There are two actuators accessible from left side of module - defrost and floor - remove panel above brake pedal to get at these actuators.
Your floor actuator might be bad - you could disconnect from the shaft to see if actuator rotates or perhaps the shaft is binding.
Replacement and/or testing for any of the actuators provide instructions to calibrate the actuators ... here's a cut and paste from service manual:
Calibrate the mode actuators by simultaneously pushing the A/C and RECIRC buttons on the HVAC control module 3 times each, within 2 seconds of initial push.
1. The A/C and RECIRC button LED's will flash while this calibration is taking place.
2. The calibration will take between 10 to 30 seconds depending on battery voltage.
3. The LEDs will quit flashing when the calibration is complete.
4. Cycle the ignition and verify proper operation.
Procedures to replace any HVAC actuator are too large to post - use PM to send an email address if you'd like any of the extracts.
97 Saturn SL2 interior fan to blow heat not working paumcd S-Series Tech 1 11-05-2011 02:07 PM
Heat Not Working In 96 SC1 SickSc1 S-Series Tech 3 12-07-2009 09:42 PM
HELP!! Squicky Noise in stearing and heat in seats isn't working loly75ddl Vue Tech 5 12-21-2006 07:24 PM
A/C not working and get low humming noise when turning on the heat. jc123 L-Series General 2 04-12-2006 01:28 PM
2001 L300 AC/Heat Fan Not Working NoDents L-Series General 6 10-25-2005 09:04 AM
