Old 06-10-2013, 05:19 AM   #1
whitesl2much
whitesl2much has a spectacular aura aboutwhitesl2much has a spectacular aura aboutwhitesl2much has a spectacular aura about
Default sl2 alternator help
Long time reader, first time poster (newbie)
Lost my l200 in the divorce and I missed her so much (the car)
so I bought an sl2 and started wrenching with the help of this great forum.
but now I'm stuck! Can you please help?
1- I have a stray terminal connector that is red in color. It has two wires one solid brown, one solid white. I labeled it as alternator, but don't know why 'cause while it is near the alternator/ p.s. area, I see nowhere for it to plug into. Where is it supposed to connect to? Is it for the idiot light? Wish I hadn't been so hasty in my removal.
2- when turning the key to run, the fuel pump will make noise, but only the first two or so times. Could this be a problem? In my Chevy Colorado, it makes noise every time.
3- if a man says something in the woods and there's
no woman around to hear him, is he still wrong?
PS 99 sl2 automatic - fuel system has return line, fresh fuel
spent 5k on rebuild of engine, trans, parts etc. Itching to crank it...
promise to post pics when my new SD card comes next week.
Thanx in advance.
Add to whitesl2much's Reputation
Rate the quality of this post and help whitesl2much reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
whitesl2much is offline   Reply With Quote
Old 06-11-2013, 02:45 AM   #2
el diablo viejo
el diablo viejo's Avatar
1994 SW1
Default Re: sl2 alternator help
1) The "socket" for the connector plug is recessed into the top side of the alternator and is not easy to see.
2) Could be that your fuel delivery line is holding pressure well enough that the pump doesn't need to pre prime.
3) If you need to ask then of course he's still wrong
97 sl2 a/t 104 K
Add to el diablo viejo's Reputation
Rate the quality of this post and help el diablo viejo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-11-2013, 07:33 AM   #3
Chazberry
Chazberry's Avatar
Some insight from OldNuc . . .
http://www.saturnfans.com/forums/sho...65&postcount=2
Add to Chazberry's Reputation
Old 06-11-2013, 08:17 AM   #4
Red 2-wire plug goes into the EVO solenoid on the power steering pump. It may have looked/felt like it was on the alternator, it isn't. Hope you have small hands, unplugging it is the easy part unless maybe removing the alternator makes it easier.
1st and 2nd gen alternators have 3 wire plugs that I believe are black in color; not sure on the 3rd gen's.
Old 08-26-2014, 01:49 AM   #5
whitesl2much
You were exactly right, not sure why I labeled it alternator, guess 'cause it was above it. and I couldn't even see what I was unplugging.
Thank you
alternator...or something else? ThingOne76 S-Series Tech 4 09-23-2008 04:25 PM
¿¿Can you name my Alternator?? Aldiaz2331 Miscellaneous Tech 5 05-14-2004 09:25 PM
93 sc1 alternator kustom55 S-Series General 2 05-10-2004 10:13 AM
bad alternator mikemrq S-Series Tech 7 05-02-2004 11:30 AM
alternator bigad21 Miscellaneous Tech 4 06-19-2003 04:56 PM
