Old 05-16-2013, 09:09 PM   #1
mudawg
mudawg is on a distinguished road
Default What does your L200 Temp Gauge Read?
I swear my temp gauge on my 2002 l200 2.2. would never get close to half way? Lately it has been about 75 in Chicago and its consistently right in the middle at idle or a just barely under half when driving. So im curious where your temp sits at operating temp?
Thanks
Add to mudawg's Reputation
Rate the quality of this post and help mudawg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mudawg is offline   Reply With Quote
Old 05-17-2013, 09:04 AM   #2
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Default Re: What does your L200 Temp Gauge Read?
Half way between 1/4 and 1/2 regardless of speed, stop and go, outside temp or length of drive.
Jerry N
Groucho Marx
Add to s3nfo's Reputation
Old 05-17-2013, 10:01 AM   #3
pierrot
pierrot's Avatar
The temperature is varying somewhat on warmer days, from the upper 70's or so. When in motion and without the A/C on, the temperature gauge needle is typically between 1/4 and 1/2. When stopped at a traffic signal the temperature creeps towards half, but drops back below when moving again. On very warm days, high 80's and 90's, the gauge needle will ride near 1/2.
The first time I saw what you've described with my LS 1 was before my first replacement of the thermostat several years ago. Once that was replaced the operating temperature dropped down again to between 1/4 and 1/2. However, this temperature issue has been happening since some time last Summer even after replacing the thermostat. (I'm satisfied that it's functioning normally at present.) It just now makes me think that I may be having an issue with the fan/s not engaging as they ought to since my previous experience had been that the temperature gauge had held steadily at about "3/8" until outside temps were very high. I've never had any kind of service light illuminated on this car ever so I'm not yet sure what to think of this.....hmm....food for thought.
Thank you for bringing up the question!
293,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 05-17-2013, 01:38 PM   #4
mudawg
Thanks for the replies guys :-) I have 160k so ill replace the thermostat just to be safe and double check the fans
air cond. fuel gauge and temp gauge not working. Help?? brielle L-Series General 12 09-14-2016 08:07 PM
Where does your temp gauge read on your V6 L-series? clean93 L-Series Tech 13 08-26-2011 11:50 AM
fuel gauge no read 93 sl1 bates S-Series Tech 1 10-05-2009 04:34 PM
93 sl1 fuel gauge don't read can anyone help? bates S-Series Tech 1 09-28-2009 07:02 PM
Does Temp Gauge Read Right When Low on Coolant? spencerb S-Series Tech 11 12-09-2004 11:48 AM
