Old 05-12-2013, 05:12 PM   #1
mbr
mbr is on a distinguished road
1998 SW2
Default P440 code and bucking/missing
I'm getting the ol' 440 code. Cleared it once and it came back. There's no obvious vacuum leaks and the gas cap is ok. I'm also getting a bucking at low- 2k rpm. It's almost a miss or a hesitation, but doesn't feel like it's electrical. ETCS & thermostat are good. PCV was changed to the open orifice style. Otherwise it runs fine and mpg is normal.
Can the code and the bucking be related? What's the other obvious things to look for starting with the most common causes and/or the simplest.
Thanks
Accuracy MATTERS!
Add to mbr's Reputation
Rate the quality of this post and help mbr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mbr is offline   Reply With Quote
Old 05-12-2013, 08:53 PM   #2
marko16
marko16 has a spectacular aura aboutmarko16 has a spectacular aura aboutmarko16 has a spectacular aura about
Default Re: P440 code and bucking/missing
Try a fine mist sprays around the wires as you give it the gas. Do it in the dark or listen for a snap. Mine is doing exactly what your is and it's the plug boot/wire. I also thought it to be what you mentioned, but sure enough I finally caught the snap of the spark though the boot. At 2k plus it clears up and runs fine.
Add to marko16's Reputation
Rate the quality of this post and help marko16 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marko16 is offline   Reply With Quote
Old 05-12-2013, 08:59 PM   #3
mbr
1998 SW2
It doesn't do it at idle, only under load at a lowish rpm. Would that cause the trouble code?
Accuracy MATTERS!
Old 05-12-2013, 09:28 PM   #4
Check that the purge solenoid to the throttle body hose is connected at the purge solenoid as they tend to fall off. The P0440 is large leak and having the hose fall off will set the large leak code. It will also make the engine run lean at very light loads.
Old 05-12-2013, 09:40 PM   #5
mbr
1998 SW2
I'll check that. Is that located above the starter?
Accuracy MATTERS!
Old 05-12-2013, 10:30 PM   #6
Yep, way up there in the dark.
Old 05-13-2013, 09:35 AM   #7
marko16
If the other suggestions don't help, the spark won't leak at idle, the load increases the resistance at the plug and it seeks ground, so to speak, through the wall of the wires. Cold and damp will also add to the problem.
95 SW2 code 26 from missing A/C relay? 800xl S-Series Tech 11 03-27-2013 01:36 PM
Missing code/bad gas Wingman1'slady S-Series General 14 02-22-2013 06:30 PM
Need my paint code, 96 sc2 black/gold metallic (I'm missing the trunk panel w/code) DJboozeAlot S-Series General 3 03-18-2011 09:26 PM
97 SL2 "bucking and missing" when cruising JOE PA S-Series Tech 4 09-27-2009 12:27 AM
Vue V6 Bucking dnienalt Vue General 8 09-18-2003 04:58 AM
