Old 05-10-2013, 12:25 AM   #1
natesl1
natesl1 is on a distinguished road
1993 SL1
Default sl1 sl2 swap
ok i have a 1993 sl1 5 speed and im wanting to do a motor swap i want a dohc what do i need to do for the swap to work right? and what am i looking at price. wise?
Add to natesl1's Reputation
Rate the quality of this post and help natesl1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
natesl1 is offline   Reply With Quote
Old 05-10-2013, 01:13 AM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: sl1 sl2 swap
Price will depend on where you get the parts and how much of the work you do yourself. As for what you need, you need a DOHC engine from a compatible year, PCM, and full drivetrain wiring harness.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 05-10-2013, 01:24 AM   #3
If you want it to emulate an SL2, even functionally, you'll need to swap more than the engine.
There are, give or take, 234897159 threads covering various swap projects here on SF, including a swap guide "sticky" in either the Tech or Mods section.
Add to madpogue's Reputation
Old 05-11-2013, 03:22 AM   #4
natesl1
1993 SL1
ok guys thanks
Old 05-12-2013, 10:20 PM   #5
ohioguy98
ohioguy98 is on a distinguished road
It would probably be cheaper or at least not much more, and definitely WAY easier, to just buy a decent first generation SL2 and drive it as-is. A first gennie driver can probably be had for not much more than a plausible SL2 donor, and that's before you figure in the cost in time and $ to do the swap.
Add to ohioguy98's Reputation
Rate the quality of this post and help ohioguy98 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ohioguy98 is offline   Reply With Quote
Easier to Swap engine, or swap tranny? Saturn #4 S-Series General 6 03-21-2016 09:44 AM
Engine cradle swap; tranny swap MikeNW S-Series General 6 03-11-2015 01:04 AM
96 sc2... which years of window regulators will swap? not found in swap guide... DJboozeAlot S-Series Tech 3 08-07-2012 05:45 PM
Engine swap help. Can you swap without taking off the transmission? 99 sl2 5-speed msmay0 S-Series Tech 5 06-10-2012 05:01 PM
96 SL1 w/ MP7 TRANS??? PLZ HELP!!! SWAP PCM FROM DOHC???? SWAP BOARDS??? randyshear S-Series Tech 20 11-15-2006 05:58 PM
