Old 05-09-2013, 04:59 PM   #1
cityhawk
cityhawk is a name known to allcityhawk is a name known to allcityhawk is a name known to allcityhawk is a name known to allcityhawk is a name known to allcityhawk is a name known to all
cityhawk's Avatar
1993 SW2
2001 L-Series 3.0L Wagon
Default Intermittent turn signal function. Flasher relay issue?
While waiting at an intersection to turn left this morning with my directional on, it suddenly stopped working. I tried in the other direction and it didn't work that way either.
When I got to the next intersection, where I had to turn left again, I instinctively turned on my turn signal and it worked for a while, then stopped again. This pattern has repeated itself. I seem to have turn signals for a while, then they cut out.
I've read posts about flasher relays here.... I'm not sure if they're all the same across generations, but I first wanted to check if my symptoms are typical of this relay malfunctioning or if it's likely due to something else.
Saturns:
1993 SW2 MT 186,000 hard Boston city miles ("Rozzie")
Gone but not forgotten:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
1966 Corvair Monza convertible
1928 Ford Model A Tudor Sedan
Add to cityhawk's Reputation
Rate the quality of this post and help cityhawk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cityhawk is offline   Reply With Quote
Old 05-09-2013, 05:04 PM   #2
Default Re: Intermittent turn signal function. Flasher relay issue?
Did you get out and look or did you hear it quit or the indicator went out? It does sound like a flasher as a first guess but I would be checking all ligts first.
Old 05-09-2013, 05:12 PM   #3
cityhawk
cityhawk's Avatar
1993 SW2
It stopped clicking and the arrow stopped flashing (the arrow was dark -- I have in other cars in the past had the arrow stay lit). I haven't looked outside yet though, but would it likely quit for both directions if a bulb goes?
Saturns:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
Old 05-09-2013, 05:46 PM   #4
If the clicking quit then it probably died.
Old 05-10-2013, 04:09 AM   #5
cityhawk
cityhawk's Avatar
1993 SW2
I ordered this part from RockAuto.com.
Saturns:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
Old 05-10-2013, 09:32 AM   #6
That is supposed to be the correct part and it is located on the front of the I/P Panel.
Old 05-13-2013, 04:32 PM   #7
cityhawk
cityhawk's Avatar
1993 SW2
I put the new flasher unit in the car today. It was nice of Saturn to have a diagram on the inside cover of the fuse/relay panel so I knew which relay was the flasher unit. The new one is larger (ie longer from the panel to the end of the unit) but fits fine. After installing the unit, I turned on my right directional.... it flashed on, then off, then on again then stayed on.
I flipped it to the other side and it worked fine. It has worked fine in both directions and the hazard flashers ever since with all lights flashing properly.
Just a random start-up thing perhaps?
Saturns:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
Old 05-13-2013, 06:25 PM   #8
Moderately dirty bulb contact or cranky flasher. Who knows...
Intermittent turn signal prob - Grounding issue? 92SC2 S-Series Tech 8 12-30-2010 12:48 AM
96 sl1 turn signal flasher location rlahrens S-Series Tech 2 03-02-2010 11:43 PM
More turn signal/flasher issues kdhunter S-Series Tech 6 09-02-2008 11:49 AM
Need help with flasher/turn signal failure kssherod L-Series Tech 6 12-03-2007 08:01 AM
Where is the turn signal flasher box???? mellissam Vue Tech 2 08-04-2006 03:02 PM
