Old 06-02-2013, 07:08 PM   #61
Default Re: Rebuilding the tired out $300 199K 1995 SC2
What do you mean "stuck"?
Old 06-02-2013, 07:16 PM   #62
MyloFox
MyloFox is on a distinguished road
MyloFox's Avatar
Like it won't go any farther but I can still pull it out. I've hit pretty hard and it still straight.but no matter what I do it just won't go in
Saturn: Cooler than Jupiter, but hotter than Uranus!
Cars of yore:
1998 Saturn SC2-221,000M
1997 Saturn SL1-135,000M
2000 Saturn LS1-178,000M
Current rides:
1995 Saturn SC2-210,000M
Add to MyloFox's Reputation
Rate the quality of this post and help MyloFox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MyloFox is offline   Reply With Quote
Old 06-02-2013, 07:28 PM   #63
They are tight. Check for burs on the ring groove and once it is actually in the cavity then it is block and hammer time. I think ShawnV made a video so you can see how hard to hit it.
Type this in the search box ^^^^^^ transmission seal shawnV
Old 06-03-2013, 03:25 PM   #64
MyloFox
MyloFox's Avatar
Smacked it really good and it went in! Thanks fr your help now on to finding a job so I can keep going on this thing. So glad to see it driving gain. With no door or hood.... and the steering wheel is like 20 degrees off center center and it pulls right like no ones buisness. Will post pics when I get to a computer. Phone ia stupid
Cars of yore:
Current rides:
Old 06-03-2013, 07:27 PM   #65
Sounds like you need to learn how to a DIY alignment with common tools.
Old 06-04-2013, 04:48 PM   #66
MyloFox
MyloFox's Avatar
Your kidding... you can do that? Oldnuc. Why are you the wizard of all knowledge? I dont know what i would do without you guys. Oh btw. So the sc decided to blow some fuses. Got those fixed but now the battery wont charge. Im thinking alternator died on me
Cars of yore:
Current rides:
Old 06-04-2013, 05:29 PM   #67
That would be the most likely point of failure, dead alternator.
To do your own alignment you must have a level floor. Concrete garage works, got one?
Old 06-04-2013, 05:32 PM   #68
MyloFox
MyloFox's Avatar
Gonna go get alternator tested and yeah I got a flat surface I could get into. Have to move a dead crx to get to it but it can be done
Cars of yore:
Current rides:
Old 06-04-2013, 07:04 PM   #69
If it is not absolutely level you have to mark all 4 tire points and construct pads to establish a level plain right to left and front to back. Takes a good carpenters level and a couple of straight boards to reach the front back and left right tire points. Cheap plywood will work for pads and you need at least 2 blocks of 2x4 about 4" long. You use them on the side on each tire point to act as points to set level to. Probably the hardest part of the job.
Old 06-04-2013, 07:58 PM   #70
MyloFox
MyloFox's Avatar
the space I have is Level what next?
Cars of yore:
Current rides:
Old 06-05-2013, 03:41 PM   #71
MyloFox
MyloFox's Avatar
Gonna go down today or tomorrow and test the alternator hopefully its dead honestly. If its not I dont know what else.
Cars of yore:
Current rides:
Old 06-05-2013, 05:24 PM   #72
If it is not then more testing will be in order.
Old 06-05-2013, 09:53 PM   #73
MyloFox
MyloFox's Avatar
Yay more testing.... ugg lol. Ok so I'm pretty sure its the alternator. I out In my trucks battery and the cat ran perfect for like half an hour then died. Pit the battery back In the truck and the truck baaaaarely started. Battery was super low. This truck has a new battery and never has battery issues. Was thinking of leaving the truck off and turning the saturn on and jumping it to the truck to use the volt meter in its dash. Saturn don't have one and that's all I got.
Also if I do need a new alternator. What is the easiest and fastest way to take one out and is a pick n pull alternator a good idea? I have $60 left to my name atm.
Cars of yore:
Current rides:
Old 06-05-2013, 10:35 PM   #74
Pick and pull is a shot in the dark. These are new and cheap.http://www.db-starter-alternator.com...ar-output.aspx The price includes the FedEx shipping.
Youtube, search for richpin06a saturn pulls up a long list of DIY info. This is about the only way to get it out of there. http://www.youtube.com/watch?v=iogtiYraHCg
Old 06-05-2013, 11:01 PM   #75
MyloFox
MyloFox's Avatar
So pulling the alternator out is hyper simple. Cool. And I cant afford those. I have 60 bucks left and no job. I don't have a job until this car is up and running either. Kinda nasty little catch 22. Ok ill work o. This and let you guys know. Thanks a bunch
Cars of yore:
Current rides:
Old 06-06-2013, 11:32 PM   #76
MyloFox
MyloFox's Avatar
Ok new alternator did nothing. All lights still flicker as it slowly dies. Like... the computer is dieing
Cars of yore:
Current rides:
Old 06-06-2013, 11:46 PM   #77
MyloFox
MyloFox's Avatar
I want my saturn to work.... I was really hoping this would work. What else should I look for?
Cars of yore:
Current rides:
Old 06-06-2013, 11:54 PM   #78
kevster0522
kevster0522 has a spectacular aura aboutkevster0522 has a spectacular aura about
kevster0522's Avatar
If it ran fine with a charged battery your computer is not dieing. I would check all the wiring to the alternator along with grounds. Also did you buy a new alternator or is it a junkyard part?
1995 sl1
Add to kevster0522's Reputation
Rate the quality of this post and help kevster0522 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kevster0522 is offline   Reply With Quote
Old 06-07-2013, 12:15 AM   #79
MyloFox
MyloFox's Avatar
Junkyard part. Imma go test them tomorrow or so. It only has 120000 miles on it and it looks all shiny. But gonna test It. Just wondering if I could get some help with diagrams or something for ignition. Also what the fuses on the inside panel are. I don't have a cover for it so they are just mystery fuses under the dash
Cars of yore:
Current rides:
Old 06-07-2013, 12:17 AM   #80
I may have a 95 panel diagram, will look in the AM. Do you have any electrical test equipment at all?
So it begins: Rebuilding a 1995 SC2 RalliArt16 S-Series Tech 441 05-08-2013 08:55 AM
1995 SL rebuilding front suspension bescurred S-Series Tech 1 03-16-2011 11:23 AM
Rebuilding My Starter 1995 SL2 5-spd MINICooperS S-Series Tech 13 05-17-2010 07:48 PM
Getting Tired DHOOP General Saturn Discussion 3 03-17-2001 02:29 PM
