Old 05-01-2013, 02:49 PM   #1
metroke
metroke is on a distinguished road
Default Side mirrors
Hello all
Well again something very odd happend to the Astra without any reason. The right side mirror on the door just the glass well it just fell off and fell to the floor and well it brook into a million peaces. So i call up the dealer and just for the glass 150.00$ WOW so again Ebay and i found full assembly but for both sides for 49.00$ and they come with the defrost in them. WOW GM realy makes money. So i ordered them. Now i got them and i need to replace the broken one. Does any body here done this before. I know they are just clipped on but i just want to make sure i do it the right way.
Thanks all
Add to metroke's Reputation
Rate the quality of this post and help metroke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
metroke is offline   Reply With Quote
Old 05-01-2013, 03:25 PM   #2
phatfire6
phatfire6 will become famous soon enough
phatfire6's Avatar
2008 Astra XR
Default Re: Side mirrors
  • Pry off the interior trim panel where the tweeter is located. It is held on with three retaining clips.
  • Remove the foam insulation from the interior trim panel.
  • Disconnect the speaker wiring connector and set trim pieces aside.
  • Disconnect wiring connector for the mirror.
  • Remove three mirror retaining screws (torx screws) to remove mirror assembly from door.
  • Remove outer cover by prying on the outer edge. It is held by four clips on the top and four on the bottom
  • Install outer cover on your new assembly and install new mirror assembly in reverse order.
Add to phatfire6's Reputation
Rate the quality of this post and help phatfire6 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
phatfire6 is offline   Reply With Quote
Old 05-01-2013, 03:31 PM   #3
metroke
Sorry you do not need to take off the mirror. This is only the mirror by it self that i need to change. We do not need to take out the hole mirror for this.
Old 05-01-2013, 05:12 PM   #4
phatfire6
phatfire6's Avatar
2008 Astra XR
Okay then.
  • Depress the upper-inner corner of the mirror (side closest to car)
  • Pry on the outermost corner to separate mirror backing from the retaining clips
  • Disconnect the two defrosting element wires
  • Install wires on new mirror
  • CAREFULLY depress the mirror into the retaining clips. Too much force on a single point can crack the mirror, so try your best to spread out the pressure.
  • Have a beer and smile at your handiwork
Old 05-01-2013, 05:51 PM   #5
metroke
Done it perfect fit and perfect job without the beer haha just for other users when you do this do it while you are behind the mirror much easier then if you where in front.
Thanks all
Case closed
Old 05-01-2013, 06:27 PM   #6
Astra La Vista!
Astra La Vista! has a spectacular aura aboutAstra La Vista! has a spectacular aura about
Astra La Vista!'s Avatar
2008 Astra XR
Well, that took all of only three hours from initial post to "level completed". Good job!
"That's a Hruck Bugbear, manufactured in Eastern Europe in the eighties and imported to the States. People mock it as a poor man's Yugo. I consider it the pinnacle of Cold War Balkan engineering."
Add to Astra La Vista!'s Reputation
Rate the quality of this post and help Astra La Vista! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Astra La Vista! is offline   Reply With Quote
Old 06-03-2013, 09:18 PM   #7
todaresqSL2
todaresqSL2 is on a distinguished road
2007 SKY
2008 Astra XR
OK... Mine fell out last night. This is looking to need a recall.
Here is a shot of it...
At first it looked like it had smoke damage. Nope... is just the metallic backing. Only the glass fell off.
Add to todaresqSL2's Reputation
Rate the quality of this post and help todaresqSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
todaresqSL2 is offline   Reply With Quote
Old 06-06-2013, 04:28 PM   #8
Haps
Haps is on a distinguished road
Haps's Avatar
2008 Astra XR
My right side mirror glass also fell off...
Where have you guys been sourcing a replacement, and for how much?
Add to Haps's Reputation
Rate the quality of this post and help Haps reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Haps is offline   Reply With Quote
Old 06-06-2013, 04:40 PM   #9
todaresqSL2
2007 SKY
2008 Astra XR
I found one on eBay... hopefully it fits. It is on the way now.
I contacted Saturn/GM Customer Care. The rep said to have it diagnosed... that way if I attempt to have it covered, they will have record of the issue.
Since I was also having the intermittent horn issue, the shop combined the "diagnoses" of missing mirror glass on the same work order for the horn, so it is guaranteed to be seen by GM.
I find the term diagnosis pretty funny... but that is what the GM rep said. Diagnose the missing glass...
Old 06-06-2013, 07:02 PM   #10
eneloop
eneloop is on a distinguished road
This is serious
All the best
eneloop@yahoo.com
http://www.miata.net/garage/tirecalc.html
Add to eneloop's Reputation
Rate the quality of this post and help eneloop reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eneloop is offline   Reply With Quote
Old 06-07-2013, 12:57 PM   #11
chadbt
chadbt is on a distinguished road
chadbt's Avatar
2008 Astra XR
Mine fell out a couple of months ago - the right side - but fell onto about ten inches of snow, so it didn't break. The glass place glued it back on for me.
How strange that so many have had the same problem!
Add to chadbt's Reputation
Rate the quality of this post and help chadbt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chadbt is offline   Reply With Quote
Old 06-07-2013, 11:05 PM   #12
onizuka78
onizuka78 is on a distinguished road
Same thing happened to m couple of months ago. And I got these from Ebay
http://www.ebay.com/itm/SATURN-ASTRA...ht_3098wt_1255
Add to onizuka78's Reputation
Rate the quality of this post and help onizuka78 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
onizuka78 is offline   Reply With Quote
Old 06-09-2013, 08:26 PM   #13
havi4362
havi4362 is on a distinguished road
2008 Astra XE
Good thread since this is a common issue. Love my Astra, but my right side mirror glass fell off when my friend closed the door. It shattered spectacularly. Fix this GM!
Add to havi4362's Reputation
Rate the quality of this post and help havi4362 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
havi4362 is offline   Reply With Quote
Old 06-11-2013, 03:58 PM   #14
havi4362
2008 Astra XE
Have you installed these on your Astra yet? They fit well and work ok?
Old 06-11-2013, 03:59 PM   #15
havi4362
2008 Astra XE
Thanks all
Case closed
could you send out a link to the replacement glass that you bought on Ebay?
Old 06-12-2013, 08:56 PM   #16
onizuka78
it takes time to get use to the convexe view, especially with the blue tint. But they come with wiring for your heated mirror connection. Also they can be installed in 15 mins.
Old 06-13-2013, 06:39 PM   #17
Toms XR3
Toms XR3 is on a distinguished road
2008 Astra XR
Well, my passenger side mirror just fell off today too. $60 for the dealer to order it and there will be labor added on to that when it finally arrives. The glued area looks EXACTLY like the picture posted here.
Add to Toms XR3's Reputation
Rate the quality of this post and help Toms XR3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Toms XR3 is offline   Reply With Quote
Old 06-13-2013, 08:06 PM   #18
Tom S2
Tom S2 will become famous soon enough
Tom S2's Avatar
2008 Astra XR
I had the glass (which comes with the plastic back) shipped from a place in England for about $30 total. It was here in a few days. The labor to install the glass was about one minute total. connect the heater wire, line the glass up, and gently press. Viola!
Astra XR-3-5 HP - Hamster Powered!
Dealer added options, & Infinity speakers.
Add to Tom S2's Reputation
Rate the quality of this post and help Tom S2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tom S2 is offline   Reply With Quote
Old 06-18-2013, 09:14 PM   #19
havi4362
2008 Astra XE
Ordered a $20 replacement mirror on ebay on monday night, so i should get it friday, and i'll post back as to how it fits. seems like a good cost-effective solution, although GM really should warranty this.
would've posted the link, but i haven't made 15 posts yet
Old 06-18-2013, 10:36 PM   #20
JacobJudt
JacobJudt is on a distinguished road
2008 Astra XE
this happened to me as well this past winter, the snow caught the mirror so i just used some 3m adhesive and that seemed to do the trick. super weird
Add to JacobJudt's Reputation
Rate the quality of this post and help JacobJudt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JacobJudt is offline   Reply With Quote
upscale side mirrors avenutolo Aura General 8 08-18-2008 08:03 PM
Side mirrors Alex_SC2 S-Series General 9 10-19-2006 05:47 PM
Replacing side mirrors Spacepope Ion Tech 5 12-20-2005 10:39 PM
side view mirrors sp33doe L-Series General 1 12-12-2003 06:02 PM
Did you know the '97s had folding side mirrors? auxmike General Saturn Discussion 7 02-24-2003 09:56 PM
