Old 04-24-2013, 08:16 AM   #1
hunt4steve
hunt4steve is just really nicehunt4steve is just really nicehunt4steve is just really nicehunt4steve is just really nicehunt4steve is just really nice
hunt4steve's Avatar
1993 SC1
Wrench Hunt4Steve's 1993 Brake Caliper rebuild with red Calipar paint
When working with Calipers it is usually easier to take in your old calipers to the local AutoParts store and get another set of calipers. However, because I had the time I decided to rebuild my own calipers. I wanted to figure out what it takes to rebuild a set of calipers, as well as taking the time to really clean them up and get em painted.
Dirty calipers that have been coated with oil and dirt
Lots of rust and nastiness abounds here
When pulling these apart, don't forget to get the snap ring out. You may or may not need it again.
On the left is the front caliper piston, much larger, and on the right is the rear caliper piston. The rear caliper piston has a worm gear on the inside that is designed to creep out each time you use the E-brake.
Here are the internal components of the rear caliper piston
Add to hunt4steve's Reputation
Rate the quality of this post and help hunt4steve reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hunt4steve is offline   Reply With Quote
Old 04-24-2013, 08:38 AM   #2
hunt4steve
hunt4steve's Avatar
1993 SC1
In order to clean them, I started off with an angle grinder steel brush. This did ok, but jeesh, it was hard to get the brush into the nooks and crannies of the caliper. So, I looked around for an easier method of removing the rust.
I decided to use a tried and true method for removing rust from metal. Electrolysis = "In chemistry and manufacturing, electrolysis is a method of using a direct electric current (DC) to drive an otherwise non-spontaneous chemical reaction. Electrolysis is commercially highly important as a stage in the separation of elements from naturally occurring sources such as ores using an electrolytic cell."
Here is a diagram I created, that shows a rough job of the elements involved.
Click on the image to see a YouTube Video of the process.
I would suggest that you change the video quality to HD to get a better view of the actual rust flowing from the caliper.
Ok, while the calipers are getting cleaned I picked up a set of spacers to widen the track just a bit. "hein" has a great deal on these spacers, and got them out to me in quick fashion.
Lots of rust
Test fit
New Rotors
Getting the tank prepped and put together
Calipers before being processed
Processing
Power Source
Old 04-24-2013, 09:14 AM   #3
hunt4steve
hunt4steve's Avatar
1993 SC1
Processing
Green goop coming off the calipers
More goop as times goes on
More rust coming off....
eeeewwwwwww...........
juice flowing through the power source
Here are the calipers after being pulled from the tank. While these calipers may look like nothing has been done, a quick run over with a brush will remove this loose coating.
Cleaned up and ready for some paint
Old 04-24-2013, 09:19 AM   #4
hunt4steve
hunt4steve's Avatar
1993 SC1
VHT red caliper paint
Probably a good idea to remove the masking tape before cooking 'em
$10 dollar toaster oven off of Craig's list
Brand new brake clip parts
Putting the seal and boots in
AND of course, I wouldn't be able to complete a project without Murphy's Law raising up and biting me. This incorrectly sized piston seal was in the correctly labeled package and box, but is of the wrong size. RockAuto was good about sending me out a replacement part at no charge.
Parts
Rubber boots
Rear brake caliper
Looking pretty good
Old 04-24-2013, 09:29 AM   #5
jimboman
jimboman is on a distinguished road
jimboman's Avatar
2001 SW2
2005 ION-2 Sedan
Default Re: Hunt4Steve's 1993 Brake Caliper rebuild with red Calipar paint
That's quite an operation you had going there. Nice thread. Electrolysis makes a lot of sense for cleaning up the cast iron.
I recently rebuilt my calipers, but I didn't go through nearly this much effort. Thankfully mine weren't as dirty as yours. I just scrubbed the caliper bores and pistons clean with brake cleaner and some rags.
Add to jimboman's Reputation
Rate the quality of this post and help jimboman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jimboman is offline   Reply With Quote
Old 04-24-2013, 09:32 AM   #6
hunt4steve
hunt4steve's Avatar
1993 SC1
Happy Re: Hunt4Steve's 1993 Brake Caliper rebuild with red Calipar paint
I had plenty of time on my side so I decided to make it an all out operation. Between waiting on parts and working on other car-related things, I could wait for the calipers to percolate....
Old 04-30-2013, 02:35 PM   #7
hunt4steve
hunt4steve's Avatar
1993 SC1
Wrench Bleeding of the brakes
Stu provided me with some good information concerning bleeding of the Saturn Brake System.
http://www.brakeandfrontend.com/Arti...irst_time.aspx
Delphi/Delco VI
The Delphi/Delco VI was introduced in 1991 as an option on Saturn, Buick Skylar, Oldsmobile Cutlass Calais and Pontiac Grand Am models, it soon became standard equipment on most General Motors front-wheel drive passenger cars until 1998.
Before the brakes can be bled, the front and rear displacement pistons in the modulator must be in the top most or "home" position with their check balls unseated. If the pistons are not in this position, they will not allow the brakes to be bled.
The two ways to home the pistons are with a scan tool (which is the preferred technique) or with a special manual procedure. If using a scan tool, select the "ABS Test" mode, then the "manual control" or "motor rehome" option. The motors in the modulator can now be commanded to drive the pistons to their home positions. The motors will not return to their home positions, however, if the ABS warning light is on or if there are any fault codes present in the system. All faults must first be repaired and all codes cleared before the pistons can be homed.
Once the pistons have been homed, bleed the modulator starting with the rear bleeder screw first. Attach a length of clear tubing to the rear bleeder screw, and submerge the other end in a clear container partially filled with brake fluid. Open the bleeder screw one more turn and apply pedal pressure. Close the bleeder screw when the pedal bottoms out. Repeat until no bubbles are in the fluid. Then repeat this procedure for the front bleeder screw on the modulator.
Once the modulator has been bled, the brake lines can be bled manually or with pressure equipment in the following sequence: right rear, left rear, right front, left front.
To bleed the system without a scan tool, start the engine and allow it to run for at least 10 seconds, making sure the ABS warning light is off. Do not touch the brake pedal during this time. This will allow the ABS system to initialize itself. Make sure the ABS warning light goes out after three seconds (if it remains on, further diagnosis with a scan tool will be necessary before the system can be bled.) Turn the ignition off and repeat this procedure a second time. Turn the ignition off and bleed the modulator and brake lines using the same procedure described above.
Bendix 10
When filling the system with brake fluid, a special procedure is needed to assure a complete fill. Air inside the system may set a primary pressure/delta pressure fault message.
Fill the reservoir to the full mark.
Start the engine and pump the brakes until the booster pump/motor assembly turns on.
Stop pumping the brakes and wait for the pump to shut off.
Recheck the fluid level and add as needed.
Before bleeding the brake lines (manual, pressure or vacuum), depressurize the accumulator (pump pedal 40 times with key off). Then proceed as usual using the following sequence: left rear, right rear, left front and right front.
Fortunately, I did bleed the two piston valves, which allowed me to bleed the rest of the brake system. So, the ABS piston's had to have been "homed", because I was able to bleed the rest of the system.
Here is more information related to Brake Bleeding
Old 04-30-2013, 06:38 PM   #8
Ramics
Ramics is on a distinguished road
Ramics's Avatar
Excellent Work!
Add to Ramics's Reputation
Rate the quality of this post and help Ramics reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ramics is offline   Reply With Quote
Old 04-30-2013, 06:44 PM   #9
hunt4steve
hunt4steve's Avatar
1993 SC1
Wrench Re: Hunt4Steve's 1993 Brake Caliper rebuild with red Calipar paint
Originally Posted by Ramics View Post
Excellent Work!
Thanks....
Here is a another pic, close up:
Old 05-10-2013, 06:03 PM   #10
hunt4steve
hunt4steve's Avatar
1993 SC1
Roll Eyes ABS sensors
Recently I've had the ABS light stay on. Actually, it's always been on. There is something wrong with something somewhere in the system. The Brakes work great, no issues with those, but the ABS portion is not up to par.
I knew that that front ABS sensors were messed up, so I figured I might start with replacing those.
Note how the sensor on the left is missing the post that positions the sensor on the back side of the spindle. This was the case on both the front left and right sensor. After replacing them.....I've still got the light. So, I'll look at it later.....
Old 05-10-2013, 07:05 PM   #11
hunt4steve
hunt4steve's Avatar
1993 SC1
Happy Splash Guard
When working on the brakes, I took the time to get the correct fasteners (PAS1861-25 Rocker Panel, Wheel Liner Retainers Saturn) from an online retailer, Clips and Fasteners so that I could properly re-install the splash guards. Note they work very well...
Old 05-11-2013, 04:56 PM   #12
junker
junker has a spectacular aura aboutjunker has a spectacular aura aboutjunker has a spectacular aura about
junker's Avatar
1995 SW2
I'm impressed and would like to try this someday on other parts. Out of curiosity how long did you run them in the tank?
Great job.
My Saturn Videos: http://www.youtube.com/dosumpthin
Add to junker's Reputation
Rate the quality of this post and help junker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
junker is offline   Reply With Quote
Old 05-11-2013, 06:18 PM   #13
The current and electorlite determines the time but basically until it is clean and keep the current at 2 to 4 amps if using an adjustable DC source.
Old 09-07-2013, 03:07 PM   #14
shim bucket
shim bucket has a spectacular aura aboutshim bucket has a spectacular aura about
1996
Hunt4steve great job! Did the rebuild kits for the rear come with the rubber grommet for the parking break actuation shaft? The rear calipers for these Saturns are expensive. Advance has them for $62. I replaced the passenger side rear but want to rebuild the driver side. I already rebuilt the fronts. Kits were $1.85 each for the front from rock auto.
Does kit come with rubber grommet just under threaded portion?
Add to shim bucket's Reputation
Rate the quality of this post and help shim bucket reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
shim bucket is offline   Reply With Quote
Old 04-28-2014, 10:26 AM   #15
hunt4steve
hunt4steve's Avatar
1993 SC1
You know, I don't recall. Sorry for the late response....been too busy working on other cars, etc.
Old 04-28-2014, 05:37 PM   #16
laser3kw
laser3kw is on a distinguished road
2000 SC1
hunt4steve- great write up. Now I know what to expect.
I was preparing to do the same thing. After seeing the "rust" on your calipers (even in NM), I can see why mine freeze up every spring (middle of rust belt). I plan on the de-rust/paint, seal kit and new piston. I think the paint will help shed off water, snow and grim and hold off the corrosion that binds them up.
Add to laser3kw's Reputation
Rate the quality of this post and help laser3kw reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
laser3kw is offline   Reply With Quote
Old 04-28-2014, 05:54 PM   #17
caveeagle
caveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of light
caveeagle's Avatar
What kind of wheels are those? they don't look aftermarket, but I'm pretty sure ther are not saturn.
Mark
'05 Vue, '02SL1, '01SC2a, '01SC2b, '99SL1 :::::> '04 SVT Cobra, '67 Mustang Vert.
Add to caveeagle's Reputation
Rate the quality of this post and help caveeagle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
caveeagle is offline   Reply With Quote
Old 04-28-2014, 07:25 PM   #18
hunt4steve
hunt4steve's Avatar
1993 SC1
Default info
laser3kw:
Glad it could help somebody. I figure as long as I'm in there, might as well take some pictures and see if I can document my work.....
caveeagle:
The wheels are from an Acura. They didn't quite fit the bore of the saturn, but a file fixed that in quick order....
Hunt4Steve's 1993 MP2 5-spd Transmission rebuild hunt4steve S-Series Tech 34 05-01-2017 08:16 AM
Hunt4Steve's 1993 SOHC 1.9L Engine Rebuild hunt4steve S-Series Tech 48 04-23-2014 11:05 AM
Front brake caliper rebuild help dddaaa S-Series Tech 13 09-14-2013 09:55 PM
Hunt4Steve's 1993 Front Wheel bearing replacement hunt4steve S-Series Tech 1 04-23-2013 03:22 PM
rebuild front caliper now brake does not feel right mewant2b S-Series Tech 1 08-17-2009 10:30 AM
