Old 04-21-2013, 07:55 PM   #1
kevster0522
kevster0522 has a spectacular aura aboutkevster0522 has a spectacular aura about
kevster0522's Avatar
Question Cracking inner door panels
I finally decided to rid myself of rattling doors at idle and replace every clip on the inner door panels. While I was taking them off I discovered they are badly cracked along the armrest and handle. Has anyone else had this issue and found a way to fix it? right now my plan is to try to reinforce it with some resin jelly that we used to repair a rusted fender on my sisters van. I'd love your input.
Thanks in advance
Add to kevster0522's Reputation
Rate the quality of this post and help kevster0522 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kevster0522 is offline   Reply With Quote
Old 04-21-2013, 10:27 PM   #2
off-track
off-track's Avatar
Default Re: Cracking inner door panels
Wow! I don't recall seeing anything like that posted here before?? IIRC there have been a few about cracking of the arm-rest area nothing like that! I have no experience with with that product but please keep us posted with how you find it works.
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 04-21-2013, 11:24 PM   #3
bumpdraft
bumpdraft's Avatar
1998 SW2
I used JB Weld smeared into carbon cloth.
I saved a bunch of the backer peel paper from UPS labels. Lay the fiberglass cloth on the slipery paper (or even a paper plate) and use a plastic bondo spreader to force JB Weld into it. Not quite the way NASA would do it, but close
Righthere:
http://www.saturnfans.com/forums/sho...ght=door+panel
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Old 04-22-2013, 09:51 PM   #4
kevster0522
Thanks for the response Bumpdraft I wouldn't done what you said but I figured I might as well use what I have around.
Alright this is what I did. I took that body filler that I had and it actually worked very well. The panel doesn't flex nearly as much as it used to. It might look kind of sloppy but that's because the filler was very hard to work with. it was like trying to spread sticky pudding and it is usually sanded down smooth but nobody will see behind the door panels. I also had put a very thin layer around the where the handle bowl thing is otherwise if it was too thick it wouldn't fit on right (I figured a little is better than nothing ).
Also does anyone know where I can get new door clips? I stopped at fleet-farm and they didn't have any of the right kind. When I went to O'Reilly they had a package of 2 for $2.50 which I thought was very overpriced.
Although driving without the door panel does get rid of the rattling
Cracking Polymer Panels cam General Saturn Discussion 4 08-15-2010 09:15 PM
Cracking Polymer Panels? Big Nickel Vue General 27 09-30-2007 07:07 PM
door panels helixdork S-Series Mods 1 06-18-2007 06:02 PM
Panels cracking in extreme cold weather? lone_wolf Ion General 3 03-30-2005 11:27 PM
LS2 Door Panels Rdhedgrl L-Series Tech 5 10-25-2001 01:52 PM
