Old 04-08-2013, 07:12 PM   #1
Gmaan39
Gmaan39 is on a distinguished road
Question Rough Idle and misfire
My 2001 L200 2.2 (35,000 miles) has been idling rough and misfiring with no acceleration problems. The cooling fan sometimes will come on as soon as the car is started and stay on while other times it goes on and off intermitently. (A/C is off). I just replaced the ICM and I'm still having the same problem. I checked the intake manifold and there are no leaks. Any other thoughts before I run out and drop tons of money on all parts imaginable? Thanks!
Add to Gmaan39's Reputation
Rate the quality of this post and help Gmaan39 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gmaan39 is offline   Reply With Quote
Old 04-08-2013, 07:40 PM   #2
Default Re: Rough Idle and misfire
Check for a disconnected/damaged air temperature sensor behind the front grille.
Old 04-08-2013, 08:11 PM   #3
Gmaan39
I'll check that out. Also, just on a side note, I pulled the codes and I'm getting the P0300. I also uninstalled the new ICM and reinstalled the old one. I'm still having the problem but not as severely.
Old 04-09-2013, 02:20 PM   #4
u35828
u35828 is on a distinguished road
u35828's Avatar
2003 L-Series 2.2L Wagon
I had a similar complaint with my 2003 LW200. Diagnostic codes determined that a bad fuel injector was at fault.
"There's no replacement for displacement."
-Walter Owen Bentley
Add to u35828's Reputation
Rate the quality of this post and help u35828 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
u35828 is offline   Reply With Quote
SL1 - Intermittent rough idle, misfire, almost stalls... hydromech S-Series Tech 8 09-27-2012 10:24 AM
99 sl2 misfire rough idle jalanshort S-Series Tech 23 04-30-2012 12:47 AM
Misfire, Rough Idle getz_999 S-Series Tech 2 07-15-2010 01:59 PM
Misfire PO306 and rough idle mmendez L-Series General 3 03-09-2008 01:19 PM
rough idle, rough sluggish pickup, 97slw smiles233 S-Series General 7 10-14-2005 03:28 PM
