Old 03-30-2013, 02:35 PM   #1
sdmcb
sdmcb is on a distinguished road
Default 200k
I blew a dif pin in my tranny..replaced it with a junk yard tran..had a shop replace it..they put in dex 6 fluid..said he read thats what it needed..tranny whines at 25 mph......what do you think...drain tranny and refill with normal fluid.....twice..before I blow another dif pin?
Add to sdmcb's Reputation
Rate the quality of this post and help sdmcb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sdmcb is offline   Reply With Quote
Old 03-30-2013, 03:10 PM   #2
Madness10
Madness10 will become famous soon enough
Madness10's Avatar
Default Re: 200k
NEVER EVER use Dex6. Not compatible with SATURN trans. Saturn trans are not GM trans. Need to get that fluid out ASAP.
Add to Madness10's Reputation
Rate the quality of this post and help Madness10 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Madness10 is offline   Reply With Quote
Old 03-30-2013, 05:41 PM   #3
anmasher
anmasher's Avatar
Default Re: 200k
Correct, that fluid will aid in ejecting the differential pin from the transmission. OldNuc has said it can cause cone separation on the synchros also.
Add to anmasher's Reputation
Rate the quality of this post and help anmasher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-31-2013, 03:22 PM   #4
colonelhogan44
colonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nice
colonelhogan44's Avatar
Default Re: 200k
I ran my auto for 50k miles on dex 6 -- no ill effects whatsoever. I have since changed back to dex/merc.
This was when dex 6 was just released and it was touted as a direct replacement for dex 3.
I'd drain it, though.
Mechanical Engineer - I make parts, like blend door actuator gears.
2005 Volvo S40 T5 AWD - 62k
1998 SL2 - 240k
1993 Geo Tracker 4x4 - 134k
1996 Geo Tracker 4x4 - 106k
1987 Mercedes 300D - 154k
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 04-03-2013, 07:59 PM   #5
sdmcb
Default Re: 200k
I have been looking for a fluid that will work since GM stopped the rights to making dex 3....anybody find one that actually works without killing the the trans? And by the way..now I think I know why my old tranny failed...went to the dealership to buy new fluid..did not know about the dex 6 issue..That Is What They Sold Me.. Live and learn...
Old 04-03-2013, 09:44 PM   #6
ninetynineSC2
ninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura about
ninetynineSC2's Avatar
Default Re: 200k
I think I put Mobil1 in mine...Whichever said it was Dex3 compatible. Don't recall what brand, it was quite a while ago. I live in Iowa as well. What part are you in?
Current:
1999 SC2, 186,XXX
Past:
1989 Mustang LX, Unknown mileage(JY engine in it when I got it)
Add to ninetynineSC2's Reputation
Rate the quality of this post and help ninetynineSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ninetynineSC2 is offline   Reply With Quote
2001 sl 200k+ mi? SaturN S-Series General 19 06-16-2012 07:56 AM
The SW2 finally hit 200k! ShawnV S-Series General 7 03-27-2011 01:37 PM
200K again sl2clone S-Series General 3 08-06-2009 08:07 PM
Just picked up an 04 with almost 200k! JMD Vue General 15 05-22-2009 08:00 PM
